91 DPFI EF to 93 B18B MPFI
Old May 23, 2012 | 06:26 PM
Bobalobagis's Avatar
Default 91 DPFI EF to 93 B18B MPFI
First off, Yes i used the search button. Yes I know i suck at it, and yes i used Google.
Now that that's out of the way. Awesome site. Been lurking sense 2004 , and always found what i was looking for.... Until now. I'm in the middle of swapping a 93 B18a1 into my 91 civic hatch with dual point fuel injection. I have a complete 93 Intrega that is going to be the donor for the swap. I was told that i could use the complete engine harness/ECU from the teg for the conversion from dual point to multi point. While also changing from OBD0 to OBD1. Is What i was told true? do i use the body harness also? I'm far from new to mechanics or to Honda's. Any and all information would be helpful. Even if its a flame or two.
Old May 23, 2012 | 07:04 PM
crx_si-r's Avatar
Default Re: 91 DPFI EF to 93 B18B MPFI
First off, the b18b came out in 94 not 93. 1993 still had a b18a1.
Second punch who ever told you you could use the engine harness to swap in the motor.
You will have to use your stock engine harness and modify it accordingly. If you don't want to modify the harness then you can guy out the entire car harness and try n make the da harness work. Doing this will only bring you back asking for help on how to fix your car because something went wrong.
Old May 23, 2012 | 07:29 PM
lol punch face, Noted. I get myself confused as i have two LS motors laying around. One b1 and one a1. Am i going to be better off buying a si engine harness and going that route? Truly sorry for all the noob questions. Ive got alot of web pages saved with this information. Just havent sat down to read most of it.
Old May 23, 2012 | 07:53 PM
crx_si-r's Avatar
Si harness will not work either. You will need to modify your stock dx harness to accept the new motor
Old May 23, 2012 | 08:34 PM
BIGef's Avatar
or you can just buy yourself a made harness from momo. Plug and play
Old May 23, 2012 | 09:27 PM
crx_si-r's Avatar
Or a brand new one from me
No modified used harnesses here
Old May 24, 2012 | 04:12 AM
Thanks for all the helpful replies.
Crx_si, what are you charging for premade harness's? Are they plug and play? Thanks for all your help?
Old May 24, 2012 | 07:07 AM
EFinAwesome's Avatar
all you need off your ls harness is injector plugs, 4 wire o2, distributor plug, believe that's it
Old May 24, 2012 | 08:12 AM
So using the dizzy plug, injector clips and o2 makes it mpfi? Dosent this keep it obd0? As I'm wanting to convert to obd1
Old May 24, 2012 | 08:26 AM
crx_si-r's Avatar
Txt me, and yes plug n play
916-541-5266
http://www.youtube.com/watch?v=puPiw...e_gdata_player
One of mine
Old May 24, 2012 | 10:42 AM
you need them but also have to change some wires around and it will be mpfi. you need a jumper harness for the obd1 which on rywire is $100. Its $190 for the vtec,distrib adapter,4 wire o2 if you want to wire less. i mention the vtec cause with the information they have on lsv now i couldnt see anyone not doing it.
Old May 24, 2012 | 10:53 AM
Ignore everything I just said save yourself the time, energy,possibility of screwing it up and go to crx si-r. I you dont believe me ask him price then look at his fb pictures.
Old May 24, 2012 | 11:47 AM
4drEF's Avatar
Keyboard Humorist
crx_si-r has helped MANY with quality and reasonable priced wiring
Old May 24, 2012 | 02:53 PM
I believe that's the way I'm going to head. For what he is asking there is no reason not to.
DaIntegra1991
Feb 5, 2013 07:27 AM
ekgcool
May 8, 2007 05:43 AM
flatblk
Aug 9, 2005 09:30 AM
Sean_b
Jun 23, 2004 01:19 PM
4dohs4mohoes
Jul 31, 2002 06:37 AM
