94 Accord wont stay cranked
My buddy has a 94 Accord with a F22B1, his water pump recently went out and he had it and the timing belt replaced. He drove it for a few days, now whenever he cranks it it'll start fine run fine for a few seconds start to misfire and idle low then die. He's done a complete tune up on it as well, any ideas what it could be? I did a compression test all cylinders were 185 except #1, it was 155. Any and all help is appreciated, thanks!
Verify the base timing is correct. Warm up the car, jumper the blue connector, set the timing so the middle of three lines red balancer mark lines up with the timing tab.
jessemace57
Jan 27, 2010 08:18 AM
