VA Honda SCCA EP CRX
Means of contact: PM or Email Jenkinsal2(at)vcu(dot)com
Price: $5000 obo including Spares
Description: This project began about two years ago when I picked the car up from someone with ~180,000mi in VA Beach. The car upon purchase needed a bit of bodywork due to a low speed collision. The frame is straight and everything aligns correctly/ tracks straight. The car has been driven less than 400 miles and 3 autox events since purchase in various states of completion of the car. Currently the car sits unfinished as I have lost motivation. Over the years of owning the car I have acquired a complete spares package that will accompany the car (details below). I would like to sell the car as a whole but may part out with enough interest. Keep in mind when making offers that the car and parts in their current condition are almost brand-spanking new. I am not one to half-*** things and I am more than willing to help the buyer through the process to finish the car if interested so they are not in the dark with what has been done. All that being said, this car WILL be very competitive in E Prepared SCCA AutoX should it be completed. The car has over 10,000 invested so I will set the Starting price at 5000obo.
Build Thread And PHOTOS Can be found here: http://www.vadriven.com/forums/showthread.php?t=384377
*PARTS LIST (Im Sure I missed some things as well)*
Ground Control Coilover sleeves
Springsets 200lb/300lb/400lb/550lb
Suspension Techniques Rear Swaybar
PCI spherical lower ball joints
PCI hard rubber bushing kit
New Lower ball joints
New Reman Calipers
Hawk HPS front brake pads
Aluminum HF rear Drums
13x5.5 Enkie 92 et38 ( will need spacers)
Cantilever slicks 20x8x13
Guages and Dash panel
3 Gal Fuel Cell and New AN Plumbing
AEM FPR
Walbro Fuel Pump 190LPH
Scirocco Radiator
Butlerbuilt Aluminum Racing Seat
Willans 3” 6pt. Camlock Harness
Weldin Rollbar
Lexan and lightened Rear Hatch
New Wheel Bearings and Painted all Suspension Components
Wink Mirror
Full Race Traction Bar
D-Series 90A Motor Mounts
New Cunifer/AN brake hardline plumbing and Stainless steel lines
Adj. Brake Prop Valve
Skunk2 Front UCA camber adjustment
Ingalls Rear UCA
New Reman Master Cylinder
ARP Extended Wheelstuds
Rebuilt Steering Rack with new Quaife Quick Ratio Pinion (new rack bushings)
Bisimoto V2 Ceramic Coated Header
Cleaned and Flow tested Injectors
*SPARES PACKAGE*
Original dented hood and fenders
Original Running D15b2
Spare D15b2 block and Head Oiled and Plastic wrapped for Storage
D16a6 Cam for regrind
Spare front suspension Arms
New Injector Seals
New Sparkplug Wires
Random Assortment of brackets/clips/trim pieces
Assortment of engine sensors
Spare Transmissions DX and SI
Stock Rear Hatch and Quarter panel Glass
New Reman Calipers
AEM FPR
Scirocco Radiator
Weldin Rollbar
Wink Mirror
Ingalls Rear UCA
*SPARES PACKAGE*
New Injector Seals
New Sparkplug Wires
