WI FS: 2004 Sentra SER Spec V
My loss is your gain with this blow out price of $7000. I recently rebuilt the car over the winter of 2011/2012 from top to bottom. I also have boxes of brand new parts waiting to go on the car. Everything has less than 500 miles on it and most of that is dyno time. This car comes with everything I own for this platform. Boxes of parts, interior pieces, spare parts, etc. I am giving you it all.
For Sale: 2004 Nissan Sentra SER Spec V
Price: $7000 Firm! NO TRADES! Must sell!
Built by me and tuned by iLL Garage
Body has 90,000 miles / Motor has 5,000 miles (built by Synergy Tuning LLC)
I am the second owner of the car and have had it the last 6 years of its life.
Modifications:
-Built engine by Synergy Tuning LLC.
*Top to bottom rebuild, 07 specv rods, full ARP hardware, 3 layer head gasket, 07 specv main and rod bearings, lower temp T-stats, etc.
-Rebuilt head (also comes with a full spare head)
-New water pump
-All new gaskets
-new radiator hoses and clamps
-Modded t-stat housings
-Smoothed Intake Manifold
-SS clutch line
-Clutch Masters Stage 3 clutch
-Fidanza light weight flywheel
-Ported Treadstone turbo manifold
-Brand new Precision turbo
-Polished Tial 38mm external wastegate
-Brand new Black Tial-Q Bov
-Custom radiator
-Custom radiator over flow
-Custom aluminum Intercooler piping
-Custom intercooler brackets
-Custom fmic brackets
-Treadstone TR8 fmic
-Custom 3inch full Stainless Steel v-band downpipe
-Custom 3inch full Stainless Steel v-band exhaust
-Brand new black Treadstone couplers and T-bolt clamps
-Deatschwerks injectors *638cc @ corrected fuel pressure
-1000miles old Ksport Coilovers
-Walbro fuel pump
-Pusher fans
-Uprev Osiris tuned ECU
-AutoMeter boost and oil pressure gauge
-Brand new Innovate LC-1 wideband af gauge and sensor
-Custom Gauge pod
-Brand new Sparco steering wheel hub
-Sparco steering wheel
-NRG harness
-Front OEM Brembo Calipers (not on car)
-SS brake lines
-Super Blu DOT4 brake fluid
-Brand new Trans Fluids, Coolant, Engine Oil
-Brand new in box TDM Imports hard race bushing kit
-Brand new in box TDM Imports Qt-Link
-Brand new Eibach front sway bar w/ custom end-links
-Progress rear sway bar
-15mm rear spacers, 5mm front spacers
-225/45r17 tires
-Brand new open ended lug nuts
-Relocated battery to trunk (Red Top Optima battery)
-Brand new Kicker battery terminals
-Brand new in package 2J Racing ALKs
-Replica NISMO front lip
-DDM Tuning 6k HID's
-Custom solid trans mount
-Energy Suspension Motor Mount Inserts
I also have boxes of OEM parts and aftermarket parts that will be going with the car. You'll be getting everything I have.
*As I remember more I'll make sure to up date this list. This is only a portion of whats been done to the car.
If you have any questions please email the add and I'l return your message promptly.
*Serious inquires only and no test drives unless you have cash in hand.*
Modifications:
-New water pump
-All new gaskets
-SS clutch line
-Custom radiator
-Walbro fuel pump
-Pusher fans
-Custom Gauge pod
-NRG harness
-SS brake lines
-225/45r17 tires
This should sell pretty quick on my friend's site. www.allsentra.com
lol
Here is a video of the car out driving right after I finished it for the 2012 year.
http://youtu.be/u55kyZh6--s
ambiguous
Mar 21, 2012 04:55 PM
ambiguous
Feb 26, 2012 08:18 AM
SlidawayzSteve
Dec 26, 2010 09:27 AM
chris_c
Feb 11, 2005 04:29 AM
92tealTSI
Oct 28, 2003 06:54 AM
