which ECU? (SI or ZC)
Old Oct 13, 2002 | 06:46 PM
Aphrodavid's Avatar
Default which ECU? (SI or ZC)
read my sig for car. i am currently using a stock 91 SI ECU and its been working fine. my friend gave me a ZC ECU to use but i havent hooked it up yet. i know it will work but i just want to get everyones opinion on which ECU would be better for my application. the ZC ECU was originally for an auto but was coverted to a manual.
Old Oct 13, 2002 | 08:33 PM
Redline130's Avatar
Default Re: which ECU? (ZZZZZZZ)
I'd stick with the Si one. I think the ZC one will run too rich for the motor.
Old Oct 13, 2002 | 10:12 PM
Urban Business
Guest
Posts: n/a
Default Re: which ECU? (cyber13)
tough call. zc will let your rev higher before you get fuel kill. however valve trains are different so it may not be a good idea to do so. the ecu running rich is nothing that cant be worked out w/ an afc. stock ecus run rich as it is. dunno, if you have some sort of fuel management system i wouldnt worry about the fuel problem.
4door93civic
Jun 4, 2004 09:42 PM
stock_cx
Dec 31, 2003 10:26 AM
cr-x si
Aug 6, 2002 04:03 AM
Hondasaurs
Nov 5, 2001 04:35 PM
