Pros and cons of ITR head on a b18c
Old Oct 13, 2002 | 06:43 PM
TruePlayaz114's Avatar
Default Pros and cons of ITR head on a b18c
Ok i have a jspec b18c. 180 hp, 10:6:1 compression, LSD all that good stuff. I have basically every bolt on so now it's time to get inside of do something big. Is it worth it to put a ITR head on a jspec b18c. How much of a power gain should i expect. If you guys have any other options let me know what you think. I am just trying to get as much reliable power as i can. I'm trying to get into road racing and i'm a little into drag. But this is a daily driver so reliability is a must. I did a search but not really the answers i was looking for. What do you guys think.
Old Oct 13, 2002 | 06:47 PM
B_CRUZ!'s Avatar
Default Re: Pros and cons of ITR head on a b18c (TruePlayaz114)
skunk2 manifold for a gs-r would complement your motor along with a CTR/ITR camshafts.
Old Oct 13, 2002 | 06:48 PM
B_CRUZ!'s Avatar
sorry i didn't answer your question but the ITR head would cause you to lose compression due to the bigger size of the combustion chamber that is why I posted what I posted above.
[Modified by B_Cruz, 7:49 PM 10/13/2002]
Old Oct 13, 2002 | 06:50 PM
Default Re: Pros and cons of ITR head on a b18c (B_Cruz)
what if i put a Mugen headgasket and some new pistons?
Old Oct 13, 2002 | 06:52 PM
B_CRUZ!'s Avatar
The $$$ won't be worth the power gains. How about you get a Skunk2 intake manifold, ITR/CTR cams and port and polish your Sir-G head? Don't be so hung up on the ITR head.
this way you won't have to tinker with your pistons.
[Modified by B_Cruz, 7:53 PM 10/13/2002]
Old Oct 13, 2002 | 06:55 PM
fowler!'s Avatar
A little bit of a port and you'll have a head that flows better than an ITR head..
But if you have the cash, ctr pistons and and ITR head would be fun.
Old Oct 13, 2002 | 08:10 PM
Default Re: Pros and cons of ITR head on a b18c (fowler)
any other options to make my car faster?
Old Oct 13, 2002 | 08:16 PM
B2FiNiTY's Avatar
You got bolt ons yet?
Old Oct 13, 2002 | 08:39 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
comptech icebox/jg 2.5" header/2.5" cat/2.5" exhaust ... then get some ctr cams and gears and later on a jg manifold... fast enough...
Old Oct 13, 2002 | 08:43 PM
Kamin's Avatar
Default Re: Pros and cons of ITR head on a b18c (SkyeC)
no ****
ITR/CTR cam, JG or Skunk2 manifold, head port and polish it would fly.
Old Oct 13, 2002 | 08:56 PM
JDM88EF9's Avatar
Default Re: Pros and cons of ITR head on a b18c (C5_ALLMOTOR)
What about if you turbo charge it???
Curious to know how it would run.
Old Oct 14, 2002 | 09:10 AM
Default Re: Pros and cons of ITR head on a b18c (JDM88EF9)
is there any difference between the jspec GSR head and the ITR head besides the better flow from the ITR and the better cams in the ITR. It seems like if i just port my head and put some nice cams that would be the best setup.
Old Oct 14, 2002 | 09:19 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
100 shot. Don`t let everyone tell you that you don`t get any "respect" w/ NOS. If they do, just beat them. Best $500 you`ll spend.
Ryan
Old Oct 14, 2002 | 10:09 AM
EEK's Avatar
EEK
Default Re: Pros and cons of ITR head on a b18c (vtecvoodoo)
Ryan
one of the best ways you can go and be fast on the street/track..not that im promoting street racing
Old Oct 14, 2002 | 10:28 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Pros and cons of ITR head on a b18c (EEK)
I have an ITR motor and I must say that the GS-R head is still a killer head to start with. I'd simply port and polish the P72 head and get some better cams as others have suggested.
If you've got the money while the head is off I'd drop the pan and pull the rods and drop some ITR pistons in too. With the P72 head it would be some nice CR and you'd still have O.E reliability.
I'm still curious to see what somoone could do with the stock GS-R manifold - it just promotes such good low and mid power that I'd be cautious to ditch it so quickly. Erick's racing uses a modded GS-R intake manifold on their 10 second all-motor Civic.
Plus with the Skunk2 manifold you'll need a different ECU program that kicks VTEC in at higher than 4500rpm - this will probably make you drop out of VTEC when shifting with the SiR-G tranny.
Old Oct 14, 2002 | 10:44 AM
Gong Show's Avatar
Default Re: Pros and cons of ITR head on a b18c (B18C5-EH2)
This link should give you some good info... But If I was you, I'd just go with OS PR3's or OS JDM ITR's with a mugen gasket... CTR/ITR cams. Im looking to come close to 11.6:1-11.7:1 range with OS PR3's and mugen gasket. I was going to go CTR pistons, But decided not to go that high with OEM cams. If I had Skunk2's or JUNIII's I would go that high.
But here's the link
http://www.hybridgarage.com/tech/headswap/index.html
Old Oct 14, 2002 | 10:47 AM
JDM88EF9's Avatar
Default Re: Pros and cons of ITR head on a b18c (GONG SHOW)
Does anyone know about this setup with FI. Either NOS or Turbo?
Old Oct 14, 2002 | 10:49 AM
Gong Show's Avatar
I would think it would have to be good seeing that the ITR head will lower the compression i believe .2 points... So if you have USDM GSR block it should drop you down to around 9.8:1. and JDM block would drop down to 10.4:1 with ITR head.
Old Oct 14, 2002 | 01:31 PM
BuRcH's Avatar
port n polish` might as well go ITR pistons like others sed while yoor @ it
Old Oct 14, 2002 | 02:54 PM
b16b hatch's Avatar
Default Re: Pros and cons of ITR head on a b18c (BuRcH)
Just get a B16 head and buld it its almost the same head as the ITR head. ITR intake manifold CTR cams and dual valve springs. ITs the same and a lot cheaper. The Skunk 2 manifold costs more then the ITR manifold and they are the same but the ITR manifold will not fit the B18 head.
Old Oct 14, 2002 | 05:08 PM
00CIVICwB18C1's Avatar
b18c5 bottom end with a ported/polished gsr head would be a better combo. you get the type R pistons and have higher compression than a stock R. with some cams and an intake manifold, you'd be seeing some nice HP out of that.
Old Oct 14, 2002 | 05:45 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Pros and cons of ITR head on a b18c (00CIVICwB18C1)
There's many different options and everybody has their personal preference. Do your homework on every part that;s been listed, check out the availability to yourself, and see how much you want to spend. This should help you choose which direction you want to go.
Old Oct 14, 2002 | 06:17 PM
Default Re: Pros and cons of ITR head on a b18c (Emerica)
well here's what i'm thinking.
If I keep the head here's what would happen
Port n polish around 800
CTR and ITR cams around 600
Valve springs and retainers around 500
That's almost 2000
If i get a ITR head i can get it for around 1000
I would change the pistons and rods. 800
Hondata around 500
Almost 2500 What do you guys think?
Old Oct 14, 2002 | 07:24 PM
jas0n's Avatar
Please don't hurt me!
Ryan
yah but bottles r for babies then his motor blows but hey every 1 here has money to blow
Old Oct 14, 2002 | 07:56 PM
Gong Show's Avatar
Tp sum it all up y0... Its all about what you have the money to do and what you really wanna do..
