Built 2.0 LS Vtec Engine 9:1 AEBS Sleeved Manley Rods & Pistons and GSR tranny w/ LSD
Old May 21, 2012 | 05:26 PM
:Josh:'s Avatar
Icon7 Built 2.0 LS Vtec Engine 9:1 AEBS Sleeved Manley Rods & Pistons and GSR tranny w/ LSD
Engine has 0 miles on it. Never been started.
84mm LS block
AEBS Sleeves w/ copper O-rings on deck surface
Manley Turbo Tuff Rods and Pistons 9:1 CR
Pistons are polydyn coated on top and skirts
Rings are gapped at .012 and .014
LS Crank micropolished
ACL Race bearings
ARP main studs
LS oil pan with welded 1/2" pipe bung for turbo oil drain
Type R oil pump
B16 head
Ported and polished by Faerman Racing Engines
Supertech dual springs and Ti retainers
1mm over Ferrea Int. and Exh. Valves
Brian Crower turbo cams
ARP head studs
Skunk2 pro cam gears
AEBS intake manifold ported and matched to head
70mm BBK tb
New timing belt and water pump
cams are degreed and valve clearances checked
Looking to get $3500 for complete engine
GSR tranny with a Type R limited slip
Transmission has around 2500 miles on it
It had new seals, synchros and bearings put in it with the limited slip
Looking to get $650 for the tranny
I also have a gen 1 AEM 30-1060 ecu and AEM Injector Driver box
I'll take $850 for both
I can make package deals too as well as ship if you pay for it.
Here's a link to a for sale thread I have in a local forum with some more parts and pictures:
http://www.houston-imports.com/forum...d.php?t=648668
Old Jun 1, 2012 | 07:12 PM
hetap's Avatar
Default Re: Built 2.0 LS Vtec Engine 9:1 AEBS Sleeved Manley Rods & Pistons and GSR tranny w/
willing to sell short block?
Old Jun 1, 2012 | 07:35 PM
carbon fiber coupe's Avatar
if hetap takes the short block, id be interested in the head. You got pics? rect of work done
Old Jun 2, 2012 | 11:07 AM
njteggy's Avatar
interested in the tranny
:Josh:
Oct 6, 2012 01:37 AM
Rhymenoceros
Feb 7, 2008 06:00 AM
ExplicitSpeed
Nov 23, 2004 05:39 AM
