looking for an exhaust flange for the GE8 L15A
Hey guys, I'm looking to boost my gf's '09 Fit(GE8 L15A) and was looking for the exhaust flange for it so I can start making the manifold. I searched and searched and couldn't find it.
Also, I hear ppl having a hard time tuning the ECU using the AEM F/IC because it uses both MAF and MAP sensor although it has been done... Any alternative solution besides flashpro/kpro?
If anybody can help me get the flange made or find it or even help me on anything, I'd really appreciate it
Thanks in advance guys!!
You may have to have one made. Check Vibrant and see about a template to make one. or, you can have one cut if you have an exhaust manifold gasket.
For this, the best thing is Hondata flashpro for the Fit.. This still works for it, ironically
http://www.phearable.net/shoppingcar...pro-p-134.html
I'm assuming I can use the one for the CR-Z? I mean base MAP just to be able to drive/start tuning?
Thanks. I guess I should call and confirm too. hope thay have enough info on how to make it work.
were you able to find a flange & were you able to resolve the ecu issue?
ROTARY
Welding / Fabrication
Mar 28, 2007 07:55 PM
