Transmission & Drivetrain Gearboxes, Differentials, Clutches
help with b series trans
Old May 21, 2012 | 07:28 AM
gamble01's Avatar
Default help with b series trans
ok bought a 1991 teg the guy said it had an Ls in it but the spiders gears where shot so he went and bought a gsr trans . i took both apart started counting teeth to find ratio , the gsr matched but not the Ls, and i want an Ls fifth gear but want to make sure this is an Ls thanks
gsr trans hydro
1st gear counter42 main 13
2nd counter 38 main 20
3rd counter34 main25
4th counter30 main 29
5th counter 26 main 33
ls cable
1st gear counter 39 main 13
2nd counter 39 main 19
3rd counter 34 main 24
4th counter 32 main 29
5th counter 29 main 32
Old May 21, 2012 | 07:35 AM
94EG8's Avatar
Seagull Management
Default Re: help with b series trans
There's more than one cable LS trans, the only one you can use 5th out of is a '92 - '93 YS1 Cable trans.
Old May 22, 2012 | 12:43 AM
Mista Bone's Avatar
D Tranny Guru
The tooth counts are off on the LS tranny.
Matter of fact it appears to be a B16 tranny.
Check your tooth count!
Russyo
51
Sep 7, 2011 06:35 AM
Prodigy [EM2]
Oct 10, 2010 07:01 PM
turbo-crx
Aug 6, 2009 09:08 AM
4gExpress
11
Oct 27, 2005 07:21 PM
