f22b6 swap
ok i put a f22b6 from a 97 oddysey into my 92 accord, i bought the engine at a local pick n pull for 120 they didnt have any good f22as at the yard and my money is tight so i gotta make this work. I modified countless things to make this work.My question is can this motor run properly on the accord ecu? i have the car running but its not running perfect.the map sensor on the throttle body was busted taking it out of the car so i need some suggestions to build a block off plate.the o2 sensor was on the back of the manifold so i extended the wires although two of the wires where black so i may have it wrong. anyway to tell which one goes where?i also have to make the exhaust work but overall the motor does run well.anyone else done this couldnt find nothing on this swap.thanks
Sakamoto
Aug 17, 2018 11:11 AM
Chris Dodd
Sep 10, 2013 12:28 PM
