Question about f22 Transmissions
Old May 20, 2012 | 02:30 PM
Slammed95Cord's Avatar
Default Question about f22 Transmissions
is there a difference between the f22b1 and f22b2 trannys? i have a tranny from a 92 accord(non vtec) on my 94 EX(vtec) and its slow as hell we did auto to manual and this is the only tranny i could find at the time... im wondering if i can just get a tranny off a newer f22 or do i have to buy one off a 94-97 VTEC f22b1? basically im wondering if the ratios are the same from the b1 and b2 transmissions
Old May 20, 2012 | 03:37 PM
Thepowderblue's Avatar
Default Re: Question about f22 Transmissions
4th gear
USDM F22B1 94-97 ACCORD EX VTEC COUPE/SEDAN:
Diff Type & Tranny Codes:
STD Only = P2U5
3.285 1
1.807 2
1.193 3
0.933 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
USDM F22B2 94-97 ACCORD DX/LX non-VTEC COUPE/SEDAN:
STD Only = P2A5
3.285 1
1.807 2
1.193 3
0.903 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
Old May 20, 2012 | 08:47 PM
thank you... so now i ask... would someone with no real engine mods notice the difference in the 2? in other words should i spend the extra money for the vtec one?
Old May 20, 2012 | 10:31 PM
MAD_MIKE's Avatar
MM Gruppe B
USDM F22A1 90-93 ACCORD DX/LX COUPE/SEDAN:
STD Only = MPT3
3.307 1
1.809 2
1.230 3
0.903 4
0.705 5
4.062 final
5th gear 195/60 R15
70mph = 2782 rpm
80mph = 3180 rpm
USDM F22A4/A6 90-93 ACCORD EX COUPE/SEDAN:
STD Only = H2U5
3.307 1
1.809 2
1.185 3
0.870 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
Third and fourth are taller gears in the 90-93 EX, so that may be what you are feeling as a difference. If you really want to improve your acceleration, get a transmission from a Prelude(H22) this has shorter gears. At the cost of higher cruisng rpm.
Old May 20, 2012 | 11:00 PM
well the car was automatic... i did an auto to manual and it feels significantly slower now... the guy that did the swap said he forgot to put the abs "rings" (sensors maybe?) back on my axles and that vtec wasnt engaging because of this... it definitely feels like it has no crossover like it did before... when it was auto you could feel and hear it crossover when it kicked in...
Old May 21, 2012 | 12:23 AM
No you wont. In my eyes they are the same
If you want a faster tranny a h23 tranny will be a good pic.
Old May 21, 2012 | 04:44 AM
I'm at the specialist now... Well we used the auto computer and harness so it's not hooked to the tranny at all no vtec no reverse lights anyway to get around the reverse lights?
Old May 21, 2012 | 05:50 AM
GhostAccord's Avatar
You would be much better off running a manual ECU with a manual trans. Not quite sure what an Automatic TCU is going to show you?
FYI, VTEC is not enabled by anything ABS related. It's the vehicle speed sensor connected to the transmission that relays the vehicle speed. Do you know it they hooked that up properly during the swap?
If you are having a VTEC engagement issue you should test the VTEC related sensors and there wiring. Is the CEL on?
Old May 21, 2012 | 09:25 AM
no CEL... brakes was master cylinder... i found a new tranny, harness, and ecu im bout to buy and throw in... car still didnt pass from a loose tie rod so i had to buy new rack and pinion
Old May 21, 2012 | 12:10 PM
Auto ecus will work but you might have issues with your idle.
Old May 21, 2012 | 09:12 PM
auto ECU works you have to make it think its in park and leave the shifter switch in the car but you cant connect the auto harness to the manual tranny so you will have no vtec... its great for gas mileage but horrible for power
Old May 21, 2012 | 10:45 PM
Arthas's Avatar
What transmission did you buy??
Those gears arent exactly that much shorter, I highly doubt youll notice anything.
Old May 22, 2012 | 12:32 AM
i got a tranny off a 95 LX vtec... its not the tranny making the diff its the manual computer where i can hook up the tranny and vtec to actually work... my motor has no top end without vtec working it stops at 5k
Old May 22, 2012 | 12:48 PM
I bet you just dont know how to drive it. A manual will not be slower then a auto.
Old May 25, 2012 | 12:49 AM
right... you have no idea what youre talking about... the car redlined way higher when it was auto and it wasnt hitting the rev limiter at 5k... your ignorance is unwanted in my posts...
anyways i found out that with the auto computer still wired up the car has no idea whats going on... right now ive bought a 5spd ECU im about to put in
i read on another forum you have to wire the plug that went to the auto shifter for reverse lights, ignition release, etc... anyone got a diagram or how to on this? cant find it in search
Old May 26, 2012 | 04:14 AM
people lets not spoon feed this *******, He can look for it himself if he wants to be like that.
Old May 26, 2012 | 06:54 AM
Arthas's Avatar
Youre so ignorant, read before you make yourself look like an idiot.
His VTEC isnt working therefore taking the non-VTEC portion of the cam to revs it wasnt meant for, and hes still using an automatic computer.
So yes, an auto can be faster than a manual.
Old May 26, 2012 | 07:06 AM
Arthas's Avatar
You sound like you still need to be spoon fed, literally.
Old May 26, 2012 | 10:34 AM
i hate ppl who dont read
Old May 28, 2012 | 10:34 PM
extralargenog's Avatar
Hi
Old Jun 1, 2012 | 03:31 PM
Lost Again's Avatar
Originally Posted by extralargenog
Hi
Hello, haven't seen you in a while......broken any trans lately
The sleeper has awaken
Old Jun 4, 2012 | 12:22 PM
just an update....
im figuring the car is running in limp mode the way its stopping at 4k... im buying a 5spd ECU from this guy and going to put it in... hoping all i have to wire is the ignition release and my car will go back to running the way it should... tranny is not the issue at this point
Old Jun 4, 2012 | 12:51 PM
;O)
Old Jun 4, 2012 | 09:18 PM
ok I need help... lol...
put the 5spd ECU in today... wired the ignition release... car starts and runs but still does the same thing (revs to 4-5k and power stops, no vtec) and im not getting a CEL ... im really starting to think its in limp mode for some totally other reason... anyone got any idea?
its a 1994 accord EX sedan stock F22B1 auto to manual running an EX 5spd ECU f22 tranny...
Old Jun 5, 2012 | 02:15 PM
poorman212's Avatar
;O)
Yea, That is what I'm talking about!
I still read that "link/articale" every now and then....
