CT: All motor fully built GSR part out
Old May 20, 2012 | 02:06 PM
K PORT's Avatar
Default CT: All motor fully built GSR part out
Ran the motor broke it in. Runs on race gas got fired from my job so yeah here it goes...(motor isn't apart yet) Everything was bought brand new and like I said used for break in that is all. Nothing at all wrong with this motor/parts. Had tuner 2 cams but swapped them for pro3s. Everything is not pictured too much to post..PM me if you want more info.
Have receipts for everything.
Pretty firm on the prices..
WILL NOT TRADE ANYTHING NEED CASH
PICK UP ONLY
-370cc RC injectors --------------------------300$
-Skunk2 Pro3 cams---------------------------550$
-Gates Timing belt----------------------------80$
-Skunk2 pro series cam gears-----------------210$
-Endyn Timing belt tensioner------------------170$
-Endyn catch can----------------------------200$
-PLM Bisimoto style headers 2.75''-------------350$
-Hondata intake mani gasket------------------50$
-Jumper harness obd2b-obd1------------------65$
-Victor X intake manifold----------------------260$
-02 Wideband sensor never used AEM---------75$
-Aeromotive fuel pressure regulator never used--------150$
-Blox gold cam seal---------------------------20$
-RC injector plug n play clips------------------70$
-ACT 6 puck sprung clutch kit----------------370$
-Competition lightened flywheel 9lb-------------170$
-Brand new type r oil pump used for break in - $90
-Water pump--------------------------------$90
-AEM air/fuel gauge with pod/wire----------$70
-Mishimoto 60 degree Celsius thermostat------$35
-Spoon Sports muffler------------------------150$
$2000 FIRM
*Fully built PORTED GSR head* Super tech valves, springs, retainers, keepers, seals, guides. ARP Head studs. * Porting done by Lloyd from RCE machine shop in new milford CT.*
$2000 FIRM
GSR BLOCK
Work done by RCE machine in New Milford CT. Bored to 81.5mm.
-Decked, hot tanked, bored the whole works. Stock GSR crank.
-Clevlite bearings.
-Eagle Rods.
-Wiseco pistons 12.5-13.1 compression window
-Moroso oil pan
-ARP Main studs
-ARP flywheel bolts
I'm sure im forgetting a few things..
Also Set of MINT Type R rear seats!!! $150
http://tinypic.com/r/r94xvl/6
Old May 20, 2012 | 05:13 PM
eazybmx's Avatar
Default Re: CT: All motor fully built GSR part out
location? interested in the itr rear seats can you pm me pictures of the tops
Old May 21, 2012 | 09:10 AM
K PORT's Avatar
bumppp!!
racereaper7
Jul 3, 2014 03:15 PM
insidiouseg-6
Northern California (Sales)
Nov 20, 2008 07:19 AM
duceduce22
Jul 29, 2005 03:34 PM
W C L
Apr 20, 2004 10:15 PM
W C L
Apr 18, 2004 03:28 PM
