B series mounts for ef
Old May 19, 2012 | 09:55 AM
sd619jef9's Avatar
Default B series mounts for ef
Not sure what brackets I need for my ef to drop this b series in I have tha Hasport motor mounts for it, will brackets from a b series that was in a eg work or do I need other 1z?
Old May 19, 2012 | 10:24 AM
EFinAwesome's Avatar
Default Re: B series mounts for ef
just your b mounts and teggy t bracket
Old May 19, 2012 | 10:35 AM
sd619jef9's Avatar
But what brackets do I use to bolt tha mounts to
Old May 19, 2012 | 10:36 AM
sd619jef9's Avatar
Will tha brackets that waz on a b series in n a eg work excep for tha rear 1
Old May 19, 2012 | 10:37 AM
the b mounts for ef are made to bolt right in the ef.
Old May 19, 2012 | 10:42 AM
Spug's Avatar
He's talking about the T bracket and the post mount that the HASport mounts attach to.
Pretty sure you need a T Bracket and post mount from a 90-93 integra, the post mount that worked in the EG won't work in the EF.
Old May 19, 2012 | 10:47 AM
the only thing you need from the teggy mount wise is the t bracket. Other then that the b mounts bolt right up
Old May 19, 2012 | 11:55 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Hey kid, why don't you calm down and stop giving out bad information? Since you are CLUELESS, I will help you.
OP - for starters you should search as there are MANY lists of EXACTLY what you need. To directly answer your question you need a '90-93 Integra rear "T" bracket as well as the drivers side post mount from a '90-93 Integra for a B-series "EF" swap.
Here is a good link from a fellow member:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old May 19, 2012 | 12:39 PM
We are both right and wrong. Not needed for 93 or older and need for 94 or newer. Don't get upset its only a mistake on whats needed for different years.
Old May 19, 2012 | 07:56 PM
DO IT ON ALL FOURS
No... You are only wrong, get it right.
I never get upset; it's just the Internet.
Old May 19, 2012 | 08:29 PM
M-benz's Avatar
Lol
Old May 19, 2012 | 08:50 PM
Spug's Avatar
Maybe, but it's fairly obvious that we're talking about an 88-91, since this is the EF forum and all. So, it would be fairly obvious that you're wrong, so stop trying to cover your *** and get your facts straight before you try to give someone advice.
Old May 20, 2012 | 01:20 AM
I was referring to the motor yearnot car year smh
Old May 20, 2012 | 02:22 AM
Spug's Avatar
So, then which post mount do you need for a 90 B18 to go in an ef?
Oh, a 90-93, so it is needed, you just shouldn't have to go looking for it.
The point is that you NEED the same post mount and t-bracket regardless of the engine year. When you add alot of useless info that someone doesn't need or ask for, you confuse them.
Old May 20, 2012 | 07:09 AM
If I'm completely wrong then sorry OP just trying to help instead of ignore/bash you like most people on this site.
wing.jai
Apr 2, 2012 04:31 PM
senser310
Jan 27, 2012 11:16 AM
brian g
Jan 11, 2011 04:36 PM
guy_from_nerk
Mar 19, 2009 02:58 PM
black_krix_si
Apr 2, 2008 10:30 AM
