Vibration on acceleration help
Old May 18, 2012 | 10:39 PM
dtran002's Avatar
Default Vibration on acceleration help
Hey guys, I just finished putting in new rotors and pad on my 95 Accord LX, using mostly hand tools. Now when I hit the gas pedal, the car shake a bit and stop at steady speed. I wonder if I didn't get the hub and the bearing in enough that might have cause this shaking or is there something else?
Old May 19, 2012 | 04:50 AM
1991EX's Avatar
Default Re: Vibration on acceleration help
Vibration under accelleration is usually axle related. Never heard of rotor/pads causing vibration except under braking conditions. If it were a warped rotor it would do it mostly under braking.
Old May 19, 2012 | 06:56 AM
djkurious's Avatar
This is right on the money. I had the same issue before.
Old May 19, 2012 | 07:07 AM
mudpuppy4life's Avatar
check your CV shafts. go to a open area and turn lock to lock and listen for a clicking sound or feel for large amounts of play in the shaft by hand
Old May 19, 2012 | 08:22 AM
djkurious's Avatar
Also, have you replaced your axles lately?
Reason I asked is because I used autozone axle's and they were not balanced, resulting in a shake around 1.5-3000 RPM's. Also, is your car a auto or manual?
Old May 19, 2012 | 09:43 AM
wgbm92's Avatar
Are you saying that Autozone axles are never balanced, or yours specifically were not balanced? I am using Autozone axles myself as well and believe I am experiencing the same issue. More info would be of great help!
Old May 19, 2012 | 03:23 PM
dtran002's Avatar
Awww man, I just changed the right hand side axle, now I got to replace the driver side? It was good until I replaced the rotor. i haven't replace the driver side axle for at least a yr and a half now...I got a manual trans. Thanks all, I will have to save up for this now =(
Old May 19, 2012 | 09:37 PM
djkurious's Avatar
I installed 2 different sets from autozone and they both had the vibration. My car is also a manual.
I switched to Raxle axles (which were more $$$) and didn't have the issue anymore.
It seems that the manuals are more sensitive to unbalanced axles than the automatic transmissions.
I have installed autozone axles on automatics and have had 0 issues.
Old May 20, 2012 | 02:14 AM
dtran002's Avatar
Wait, I just installed a new axle on the passenger side, could that one be the unbalance one? How do I find out? I told my mechanic on my issue, he said the driver side is bad. Is there a way to test out?
Old May 20, 2012 | 04:11 AM
djkurious's Avatar
I don't know if there is a way to test for a unbalanced axle, but once I installed my 2nd set from the same place, that was my clear indication.
Old May 20, 2012 | 05:21 PM
dtran002's Avatar
thanks, the shop said it my half shaft bearing going bad. Trying to find it at an auto part store and they gave me a prelude axle instead, dont know why but they dont seem to have the half shaft...
Old May 21, 2012 | 03:51 AM
1991EX's Avatar
Raxle or OEM for me from now on. Just hate changing them.
Old May 22, 2012 | 03:15 PM
dtran002's Avatar
Ok, after replaced another axle, now, both side are new axles, the vibration still there. Anyone else have any ideas what else could have cause this?
Old May 22, 2012 | 04:45 PM
HATCHWH0RE's Avatar
I'm having the same issue right now with my eg. I heard that the pilot bearing could cause this. Could anyone confirm this?
Old May 22, 2012 | 04:48 PM
HATCHWH0RE's Avatar
I have new axles on both sides btw...
Old May 22, 2012 | 06:46 PM
dtran002's Avatar
One of the mechanic i went to today, said it the half shaft bearing went out, but when lifted up, the half shaft does not have any movement went shaking around. Could it be the transmission is going bad that cause this?
alswizzo
Mar 28, 2010 01:39 PM
jmai86
Jun 5, 2007 03:57 PM
nexgen91
Mar 9, 2007 11:32 AM
Got Honda
Jun 9, 2004 12:10 AM
The Toecutter
Jul 4, 2002 07:33 PM
