rywire harness
Old May 18, 2012 | 07:18 PM
EFinAwesome's Avatar
Default rywire harness
I have a 91 dx hatch that I'm going to be putting a z6 in. I'll have the z6 engine harness and I will be purchasing the obd0 mpfi to obd1 harness with distrib jumper,4 wire o2, and vtec. My question is if I buy this harness do i still do the dpfi to mpfi as-http://www.b20vtec.com/forums/technical-information/436716-dpfi-mpfi-conversion-diagrams.html-shows or is there a different way its done since I wont be making a Frankenstein harness.
Old May 19, 2012 | 12:31 PM
Default Re: rywire harness
Ok so I realized I have to use the dx harness. SO I'm still confused about the rywire harness and I tried calling when they said they were open but they wasn't. Just need some quick help please.
I have to extend the EACV,TPS,Cooling Fan Switch and add injectors on my dx harness.
Then does the distrib jumper plug into the old plug?
vtec sub harness will run straight from p28 to motor?
4 wire o2 must be cut off z6 harness and added to rywire harness?
Don't believe I missed anything. Any words of advice appreciated.
Timothy Yhtomit
Feb 26, 2019 02:25 PM
shocker911
May 14, 2010 02:29 PM
85mm LS VTEC
Feb 13, 2005 03:35 PM
dwchkypmp20
11
Dec 10, 2003 03:57 PM
