96 accord
Old May 18, 2012 | 05:54 PM
mudpuppy4life's Avatar
Default 96 accord
hello im having an issue with a high idle of 1,500rpm at running temp. brand new MAP sensor and IACV. how would i get my idle down to 900rpm? thanks mike
Old May 19, 2012 | 07:01 AM
Default Re: 96 accord
bump....does my issue have something to do with the fast idle valve? also my speedometer is not working but the plugs on the VSS are all plugged in what could be the issue there?
Old May 19, 2012 | 07:34 PM
bump....any thoughts anyone? i can care less about the speedometer problem but i need to find out how to lower my high idle
Old May 19, 2012 | 07:36 PM
holmesnmanny's Avatar
Yeah, check the faq's on how to clean out the IACV and FITV. You will need to open the top of the FITV and use a pair of needle nose to hold the screw while turning the body to push the screw in.
Old May 19, 2012 | 07:43 PM
if i clean and tighten my fast idle thermo valve would that solve my high idle issue?
Old May 19, 2012 | 08:26 PM
This normally clears the high idle problem. It won't cost a thing so I'd test it and see. It should go down to around 750-800.
Old May 20, 2012 | 06:50 AM
thanks holmes ill give this a shot
Old May 20, 2012 | 06:57 AM
dlewis2583's Avatar
^^^^^^I agree. Get u a can of carb cleaner, spray it, remove the black gunk(if any), re-install. That's it!
Old May 20, 2012 | 05:24 PM
i was told by a honda tech the parts house special iacv might be the issue too. what is the word on that?
Old May 20, 2012 | 09:58 PM
when the iacv filter gets partially blocked it only lowers idle it normally doesn't raise it. Whatever you do don't spray inside the iacv as the seals are very sensitive to the carb cleaner and will swell up and ruin the iacv. Just lightly spray the filter piece of its dirty to free the dirt.
Also, when you do the FITV, you will be tempted to hold the base and use needle nose pliers to turn the plastic piece inside. Don't do it that way. What you do is hold the plastic piece with the needle nose and turn the FITV itself. You'll find its much easier that way. If you do it the other way the plastic piece tends to strip a bit.
Old May 20, 2012 | 10:13 PM
southie's civic's Avatar
is the speedo bouncing randomly or not working entirely?? i had the problem where the wires under the intake mani were rubbing grounding out and shoring out the gauge cluster
Codyaz
Mar 30, 2015 02:25 PM
genopian
Jul 23, 2014 06:45 PM
DelSol12345
Aug 19, 2008 06:43 AM
96accordexproject
Feb 2, 2008 01:41 PM
whitediamond642
Apr 10, 2007 04:37 AM
