97 accord ex part year range
94-97 should work.
are the motor of the door lock making a noise? There is a DIY about opening and changing a little rubber part and they work.
Here is the link
https://honda-tech.com/forums/honda-accord-1990-2002-2/94-97-accord-d-s-lock-actuator-microswitch-repair-reset-2465699/
Here is the link
Crank angle sensor is in a different position on OBDI and OBDII cars. Get a sensor from a 96-97. AC compressor should be the same for all years. Just make sure you get a 4cyl or 6cyl (not sure if they are the same) depending on your vehicle.
a good guideline to follow is 90-93, 94-97( even tho the 94-95 and 96-97 have some slight differences) 98-02... some parts will fit 90-97 it all depends on what youre looking for
