Tire size for 99 Accord Coupe
Old May 18, 2012 | 06:46 AM
1991EX's Avatar
Default Tire size for 99 Accord Coupe
Getting ready to order wheels/tires for my coupe. I will be installing the Koni/GC combo to lower a little / handle good. Not going too low, but also want to eliminate as much wheel well gap as possible.
I have narrowed my choices down to 215/45/17 or 215/50/17. The 215/50 would give me more sidewall = better ride and less wheel well gap. I am just wondering if the looks would suffer. The wheels will have a little offset, so I know that using an OTS spring rate will limit my lowering ability due to rubbing.
any thoughts or suggestions?
The wheel/tire combo is from wheelfire, tires will be NEXEN N5000's. I need the better treadware vs. handling characteristics.
Old May 18, 2012 | 12:05 PM
doc@tirerack's Avatar
Default Re: Tire size for 99 Accord Coupe
215/50R17 would be recommended, as the 215/45R17 would be a little short and prone to sidewall problems if your roads are rough
chillerice
Dec 27, 2014 11:23 PM
slvrCD7accord
Mar 29, 2010 07:22 PM
ezol
Jan 24, 2007 02:18 PM
marcryan27
Oct 1, 2006 05:50 PM
blackaccordcpe
Jun 29, 2004 05:55 AM
