need stabilizer end link configuration
So I'm finally getting around to changing out my bad lower control arms. I got them off the car however I can't remember how the end links go. Can someone look at their car and give me the breakdown. the oem honda diagram isn't really specific.
should be something like starting from bottom, bolt then rubber then washer, then spacer etc etc I really need to know where the control arm and sway bar fit into the mix.
thanks to anyone that helps.
http://www.hondapartscheap.com/find-...%20LOWER%20ARM
it's parts 29 down to 7 folks. That is the end link for the 45 people that viewed this thread and didn't help.
this is the only thing holding me up
Tell ya what, I'll do you this favor.
Bolt, washer, bushing, crush sleeve, control arm, bushing, washer, spacer, washer, bushing, crush sleeve, sway bar, bushing, washer, nut. Now remember to have the cupped portion of the washer facing away from the bushing, you want the crowned part against the bushing.
The only way to install both sides without pain is to have the front of the car off the ground, and get the nuts threaded first, don't torque it down til you have both links installed.
lol nah it was more frustration at this issue I've been having this nagging issue with my car and the fact that so many people had viewed and tried to help. Most of the thread I had found in the faq were outdated so the pics didn't work. It did finally find one but I had already gone to picknpull by that time.
honda kartel 2
Jun 13, 2012 10:02 PM
