88 crx h22a4 stalling and no start issue
Old May 17, 2012 | 02:06 PM
PayMecracka's Avatar
Default 88 crx h22a4 stalling and no start issue
My fuel pump went up and I replaced it with a xenocron 255. The car started right up and drove fine and strong. I drove it later that night and it died after it got warm and stalled out. I tried to give it gas when it was dying and the car had no response. The fuel pump will come on and prime. I also have spark but the car wouldn't start. I waited a few minutes after trying to start it and it finally started. It drove and then a few minutes later it stalled and restarted. I drove it more and it stalled again and wouldn't restart. I came back to it later that night and it started and stalled again when driving, but restarted each time. When I finally got home it died and wouldnt restart and the fuel pump wasnt coming on. I tried switching out the main relay and the map sensor and still no response. The car would crank but not start. I let it sit a few days and it started right up. The fuel pump primed and I have spark. But it stalls after driving a feet and then won't restart. I've checked all my grounds and cleaned them up. No the car only cranks. Any help would be appreciative.
Old May 17, 2012 | 02:47 PM
CRX Si69's Avatar
Default Re: 88 crx h22a4 stalling and no start issue
So after a while the fuel pump stopped priming? Did that only happen once?
Check your fuel pump relay, should be under the dash.
Old May 17, 2012 | 05:02 PM
Yea it only happened the one time it primes now but won't start. The distributor has about 20 k on it new igniter and coil and cap rotor. Id really hate to have to replace it.
Old May 18, 2012 | 01:37 PM
xenocron's Avatar
How much fuel do you have in the tank?
Put more gas in and see...
Old May 18, 2012 | 06:00 PM
91EFH22's Avatar
Check fuel pressure, your pump could be running but not actually pumping anything to the front.
Old May 19, 2012 | 05:47 AM
I have a quarter tank in the car
Old May 19, 2012 | 07:19 AM
I just ohm tested the distributor and coil and all checks out. I'm about to double check the ICM
Old May 19, 2012 | 09:37 AM
It was low on gas. Guess the pick up sits higher then the factory pump on these.
Old May 19, 2012 | 08:16 PM
91EFH22's Avatar
So it runs fine now that you put gas in it? Damn im a noob, I shoulda said check for fuel before anything....
Old May 20, 2012 | 10:29 AM
Well it had a quarter tank but I guess the pick up filter sits higher on these pumps. My walbro in my hatch never had this problem.
Old May 20, 2012 | 11:44 AM
crazyassbill's Avatar
From: parkersburg,wv / belpre,ohio, wv or oh, united states
lol read the fine print on xenocron next time
For Honda applications using a 341 pump, we recommend that instead of using the generic fuel pump install kit, you re-use or replace the fuel pump sock with an OEM or aftermarket replacement sock from your local auto parts store.
Old May 21, 2012 | 10:49 AM
I think i will have to do this because now at a half tank my car stalls when I come to stops. Since this is a known problem though, xenocron as a company should fix this issue. Why sell a product that you know is not fully capable nor reliable.
wanna_run
25
Feb 7, 2012 09:11 AM
Marcpb443
Jul 16, 2006 08:59 PM
rls669
12
Jun 19, 2006 05:46 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
wadafa
Sep 21, 2004 05:00 PM
