Euro R swap into 4th gen
Old May 17, 2012 | 10:57 AM
gmuas's Avatar
Default Euro R swap into 4th gen
Hi guys! I'm plan to swap the Euro R eng/tranny into my 92 lude and was looking to find out about some problems I may encounter. I've done some digging around but only found about the IM not being able to work with the stock engine harness. Looking for input from those of you who've completed the swap. Thnx!
Old May 17, 2012 | 11:50 AM
ESP.net's Avatar
Default Re: Euro R swap into 4th gen
92-95 OBD1 Send Manifold to Rosko Racing, he will need to modify it, blocking egr ports, changing injector angle and opening for a OBD1 H22 injectors which you will need. You will also need IACV relocation kit.
Distributor wiring needed or get a obd1 h22 distributor. P13 H22 ECU or Best is P28 Chipped with Neptune or Crome with Euro R or H22 Base Map.
SLIPSTICK TIPPIN
May 12, 2006 08:26 PM
-Bionic-
Apr 20, 2004 04:07 PM
blackedoutcivic
Apr 3, 2003 08:58 AM
