What RUBBER parts to replace in the strut/spring assembly
Old May 16, 2012 | 07:16 PM
Vagitarian's Avatar
Default What RUBBER parts to replace in the strut/spring assembly
Basically Ive never had the suspension off of my 89 CRX Si so I dont really know what rubber pieces there are sandwhiched up under the body and in between the strut and coil and the "top hat" I think its called.
They list alot of pieces:
Strut mount bushing
Strut mount cap
Strut rod bushing
Shock absorer bushing
Shock absorber mounting kit
etc...
Can anyone let me know if any of the rubber pieces in there will probably need to be replaced? Maybe common failures or cheap upgrades.
Im making an order on rockauto.com hopefully tonight so any help will be appreciated, I dont wanna get caught running to 3 parts stores on install day
Old May 16, 2012 | 07:24 PM
Vagitarian's Avatar
Default Re: What RUBBER parts to replace in the strut/spring assembly
this moog kit looks "complete" but is $30
http://www.rockauto.com/catalog/moreinfo.php?pk=227540
Old May 17, 2012 | 05:51 PM
Vagitarian's Avatar
bump
Old May 17, 2012 | 06:39 PM
James89DX's Avatar
I really don't think there is any except the two bushings that fit into the top hat along with the metal sleeve, as seen in your link.
Old May 17, 2012 | 07:02 PM
Vagitarian's Avatar
So that moog kit is complete and everything I need, great thanks
Old May 17, 2012 | 09:49 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It's called SEARCH!!!
www.hondaautomotiveparts.com
This is the same as your other threads. If you don't know take the time to look at a schematic. Do some of your own detective work there Mr. Tracy.
Old May 17, 2012 | 10:19 PM
ef yu's Avatar
agree'd. this guy makes so many goddamn useless threads.
Old May 18, 2012 | 05:41 AM
Vagitarian's Avatar
Yep, got questions to ask, just getting started
Old May 20, 2012 | 06:36 PM
93delsold16z6's Avatar
Member since 09? Ur no noob
Old May 21, 2012 | 05:29 AM
DO IT ON ALL FOURS
The date joined has absolutely NOTHING to do with your ignorant statement. You can join a site and have no knowledge even 3 years later. One sitting behind the screen for 5 minutes with decades of experience while another sits behind the screen for a decade and never actually touches anything. That is the biggest problem with forums - to many people want to seem smart so they play mocking bird. Then since they aren't smart/experienced enough, they spread wrong information from somebody like themselves, since the other person "just knew" they were right. It's a vicious cycle.
Old May 21, 2012 | 11:57 AM
Well when I go on forums I look at stuff I dont even have to just to expand my current knowledge and would assume others would do the same . other than the greedy peeps in here who just post a problem, get an answer, and then never come back
edselatlife
Honda Civic (2006 - 2015)
Aug 10, 2016 04:04 AM
CptHMCrunch
May 14, 2013 04:55 PM
bokboked
Suspension & Brakes
Aug 30, 2007 11:11 AM
Repodevil
Apr 20, 2006 01:29 PM
