fuel pump wont stop priming in on position
Old May 16, 2012 | 05:54 PM
ef'dup's Avatar
Default fuel pump wont stop priming in on position
so from the start... i bought my 91 civic with a crx dash, dash is from an 88 crx. came with a 91 cluster that didnt bolt up so i bought a 88-89 crx cluster and decided just to wire it in. finished the wiring and now when i turn the key to the on position my fuel pump wont stop priming. car will start and run just fine. everything on the cluster seems to be working alright. not sure what the problem may be. havent drove the car yet since.
Old May 17, 2012 | 06:27 AM
Muckman's Avatar
Moderator in Chief
Default Re: fuel pump wont stop priming in on position
I believe the ecu controls the pump prime as you can customize the prime length in most EMS systems.
Old May 17, 2012 | 11:53 AM
SPOOLINmatt's Avatar
doesnt sound like a "problem" to me
Old May 18, 2012 | 01:59 PM
ef'dup's Avatar
well what could cause the fuel pump to continue priming
Old May 18, 2012 | 05:12 PM
fcm's Avatar
fcm
Old Fart
A constant ground to the fuel pump relays coil, [normally supplied by the ECU/ECM], possibly a short to groundof the ECU/ECM fuel pump control lead.
A constant power, [ign. switched] to the fuel pump.
A defective, ECU/ECM. 94
carracr625
Apr 19, 2019 06:29 AM
ef'dup
May 18, 2012 04:09 PM
ef-hatchcrap
Feb 13, 2010 12:02 AM
boosted k20
Engine Management and Tuning
Feb 9, 2009 09:15 AM
KansasKev
10
Jun 1, 2007 12:36 PM
