f20bs prone to valves dropping?
Old May 16, 2012 | 10:26 AM
97accordbuildlx's Avatar
Default f20bs prone to valves dropping?
literally every video on youtube, every build thread i see, or shops who have done the swap said they all ended up dropping a valve... prone to it? what could be the reason why? the stock valve keepers or something? besides this problem they seem like pretty badass engines.
Old May 17, 2012 | 08:25 PM
h2.4's Avatar
Default Re: f20bs prone to valves dropping?
Uh.... no. and it's not a problem.
Old May 17, 2012 | 10:00 PM
whats with the attitude? and thats the best response you can give? id like to know what evidence you have to support your little theory cus i feel like you dont know what youre talking about.
Old May 18, 2012 | 05:38 PM
Gunmetal_B20_Hatch's Avatar
F20C maybe... F20B not so much
Old May 18, 2012 | 08:13 PM
hmm.. the onyl reason i ask is because out of the 20 build threads videos on youtube etc, a good 15 of them said that they dropped a valve
Old May 18, 2012 | 09:07 PM
ESP.net's Avatar
You are correct there is something there far as the valves... however I think most of it is those who understand it can handle a lil more rpm and taking it to 20k rpm.
Old May 18, 2012 | 11:33 PM
yea. i guess my theory is that the head was originally designed for a slightly lower revving h22 and i think that with the f20b design it really tested the stock oem integrity of the head when peopel rev them to 8200, unless someone disagrees with anything i just threw out there. how do you think you would solve this issue? aftermarket valve set?
Old May 19, 2012 | 06:25 AM
EG1834's Avatar
It depends what causes it to drop a valve. Since the valvetrain works as a system, there are dozens, if not hundreds of variables to consider.
From what I've seen, most people don't even know seat and open pressures of their springs, much less installed or coil bind height. They think everythinig is just drop in and rev to the moon. It's rarely that simple.
Topdawgg
Jan 7, 2010 06:46 PM
flycatcher
Apr 27, 2009 06:57 PM
sneakychaos
Sep 9, 2002 05:48 PM
