cage questions
Old May 16, 2012 | 10:23 AM
Mr.Spec's Avatar
Default cage questions
I have a buddy that has a 6 point cage in his EG. its already tig welded in and welded to 6x6 floor plates. its within 1/2 all around on the body which is great for fitment. crap for adding bars to. for welds that cannot be welded all the way around, whats the rules on the gusset ? also whats the rule on the D bars ? we're supposed to have a bar go from rocker to rocker and the D bars connect to that ? with the cage in its current configuration. how legal is it or me to add a plate to the rockers and weld/tie that into the 6X6 plate ?
Old May 16, 2012 | 11:15 AM
tepid1's Avatar
Default Re: cage questions
I don't know about gusets, but the d bar thing is easy.
If the lateral bar goes from rocker to rocker the d bars can attach to the lateral bar.
If the lateral bar is between and attached to the main hoop only the d bars need to attatch to 6x6 plates on the "tunnel".
Old May 16, 2012 | 01:12 PM
ProjectLSVTEG's Avatar
I was told when my cage was cert'd that if you can't get a full weld around you need a gusset on opposing sides, be it another tube gusset or a flat plate and that you can mix and match (plate one one side, tube on the other) as long as there is one on each side of the tube with the incomplete weld.
I believe Competition makes pre-made flat gussets - http://www.jegs.com/pt/Roll+Cage+Gusset
Here's another option, personally I'd rather have these:
http://www.jegs.com/i/JOES+Racing+Pr...10400/10002/-1
Or just notch another piece of tube accordingly (what EGJDM did when he built my cage).
Old May 16, 2012 | 02:29 PM
SLIM NOTHING's Avatar
THIS WAY^^
I think this needs to be a blinking banner on HT. so many people confused about this rule.
Old May 16, 2012 | 02:43 PM
nonvtecallmotor's Avatar
Are you turning it into a 10 point? If youre leaving it as a 6 point. I would do nothing because it doesnt need cert'ed.
Old May 16, 2012 | 03:23 PM
SPOOLINmatt's Avatar
you mean i can just add a bar from hoop to hoop bent to pass around the d bars?
Old May 16, 2012 | 03:35 PM
tepid1's Avatar
I'd run it by tech, but he way I read it, yes.
Old May 16, 2012 | 03:49 PM
Mr.Spec's Avatar
do the rocker bars need to be attached to a 6x6 plate ? because i cannot put plates at the end. not that will fit at least
Old May 16, 2012 | 07:35 PM
theidealone's Avatar
Yes. Rocker bars need to attach to 6x6 plates. You can bend the plates to wrap from the rocker down to the floor, and then weld the rocker bar to the rocker portion of the plate.
Old May 16, 2012 | 09:34 PM
Mr.Spec's Avatar
so that means the rocker bars on this particular vehicle is a no go. because that 6X6 plate needs to include/ wrap up the rocker so i can weld the rocker bars to it. I cant make a small weld plate and weld that to the existing 6X6 plate because that woudlnt be legal correct ?
Old May 17, 2012 | 03:18 AM
tepid1's Avatar
There should be no problem getting a 6x6 plate back there for the lateral bar. Mig it in.
Old May 17, 2012 | 04:32 PM
My rocker plate over laps the main hoop plate. Kinda hard to see...
Old May 21, 2012 | 05:44 PM
Mr.Spec's Avatar
im definately going to use that D bar setup you got there.
another question is someone mentioned any part of the cage that I cut out. i have to leave a evidence that its been cut out before and move my new bars wherever they need to go. truth ?
Old May 22, 2012 | 09:10 AM
gc8dc95's Avatar
You cant grind any welds, if thats what you asking.
Old May 22, 2012 | 12:10 PM
Mr.Spec's Avatar
well. theres some bars in there that we do not want/need/ cannot use so do i need to leave weld evidence that there used to be a bar there and build a new one above/ around it ?
Old May 23, 2012 | 07:07 AM
gc8dc95's Avatar
No, just make sure when you remove the bar to make sure you grind as little as possible to make it smooth. Dont want to fail the sonic test because there isnt enough meat left.
TheStone
May 27, 2010 06:46 PM
dragonfly2k3
Suspension & Brakes
Feb 11, 2008 09:26 AM
Fomoco
10
May 8, 2006 03:19 PM
SuicideSlide
19
Nov 6, 2004 07:11 AM
JeremyL
Feb 15, 2003 06:59 AM
