Transmission & Drivetrain Gearboxes, Differentials, Clutches
h22a on LX trans help
Old May 15, 2012 | 02:40 PM
sjohnsonbcm's Avatar
Icon2 h22a on LX trans help
ok im new to the accord scene i figured i would try it out after selling my civic and getting gsr stolen so i purchased an H22a swapped Lx sedan. The previous owner was an older mechanic that replaced alot of worn parts on the vehicle including the clutch. After about a week of driving the car back and forth the clutch started to slip and failed to engage. When i press on the gas the car will rev really high before engaging through all gears. My question is do you all think the clutch is glazed over? If so could it be because it wasnt broken in properly because im not going to lie when i first got the car i couldnt help but push it a few times and im afraid that might have done it in please help....
Old May 15, 2012 | 02:50 PM
Thepowderblue's Avatar
Default Re: h22a on LX trans help
Where you hard on it?
I bought a cd5 with a clutch that was shredded. Like I pull it apart and the clutch was just the metal part and fibers everywhere.
Old May 15, 2012 | 03:17 PM
i wasnt too hard on it i powered through the first few gears a couple times just to make sure everything was in order then i babied it after that also if it helps there is alot of whining when the car is in gear
Old May 15, 2012 | 03:20 PM
Did you let any females drive it?
darrinirox
Oct 28, 2011 08:48 PM
charliebcdaccord
Jul 29, 2009 07:04 AM
"ANONYMOUS"
Oct 20, 2008 01:50 PM
humphreyz
Sep 18, 2005 09:14 AM
mpxs20
Jun 14, 2005 09:58 AM
