h23a headache looking to finish this project
Old May 15, 2012 | 09:03 AM
catchdz's Avatar
Default h23a headache looking to finish this project
As im sure must of u guys have read on my post before that i put a H23a vtec in my prelude, I've had a problem with the dizzy and getting a code 9 , I read this the other day and was wondering if it would help me me with my problems .........http://www.ff-squad.com/technet/ckftrick.htm.... if u have ne advice its greatly appreciated
Old May 16, 2012 | 10:22 AM
catchdz's Avatar
Default Re: h23a headache looking to finish this project
To add a little info I have a 96 obd2 Honda prelude si, with a H23a vtec, and a p06 that has been chipped already, but not sure Wat was used to tune it. After the swap the ecu has a code 9. I've had the wires from the crank senior wired to the dizzy, the dizzy itself has been change and I still have a code 9.
Sorry didn't add this first time I was busy at work so I threw that out there real quick
Old May 18, 2012 | 09:53 AM
catchdz's Avatar
No ideas ne one
Old May 24, 2012 | 06:55 AM
Rosko's Avatar
Chipped ecu's are generally junk because nobody knows exactly what they are or how they were setup. Regardless it sounds like you probably have a wiring problem.
Which dizzy are you running?
Old Aug 22, 2012 | 05:34 PM
catchdz's Avatar
sorry bout the no reply been hella busy ne ways that what i thought would be my problem bad wiring ne ways im using a TD 61U and it throws a code 9 im lost imma find someone here in miami to look at it
v8assasin
May 12, 2013 06:06 PM
redboy183
Jan 1, 2008 07:01 PM
143MYVTECEF
23
Oct 16, 2006 09:54 PM
tgh22a
Aug 20, 2006 02:34 PM
