b16a2 conversion harness
Old May 14, 2012 | 11:47 PM
mr_munro's Avatar
Default b16a2 conversion harness
Just to double check, if i was to put a b16a2 from an EM1 into a EH9 civic, do i need an obd2a to obd1 convserion harness
Thanks
Old May 15, 2012 | 06:01 AM
crx_si-r's Avatar
Default Re: b16a2 conversion harness
just do an obd1 converion with tha harnes that matches your car, not the motor. if you need one. lmk
Old May 15, 2012 | 10:47 AM
civickiller's Avatar
with your stock harness 90% will match up, only things that wont is injectors just swap over your stock injectors, distributor, alternator and you need to run the wire for vtec
im thinking sohc nonv, dont know australia's differences
i believe youll also need the rear bracket from the em1
Old May 15, 2012 | 07:24 PM
mr_munro's Avatar
thanks for the info peeps!
sir.rexington
15
Oct 20, 2010 01:48 PM
KEMIS
Aug 22, 2010 07:54 PM
EK8D15B
Sep 4, 2007 09:24 PM
pinoyboy204
May 21, 2006 07:03 PM
T3k C
Nov 29, 2005 02:09 PM
