mounting 4 point harness...
Old Oct 13, 2002 | 02:48 PM
DOHCarp's Avatar
Default mounting 4 point harness...
Im trying to mount my sparco 4 point hanesses in my 88 crx si. I have no problem mounting the lap belts because I cna use the stock seat belt mount points, but I dont knwo where to mount the rear belts. I cant seem to find any frame mounting points. does any one have any ideas, shoudl I just tap into the body?
thanks
Old Oct 13, 2002 | 03:39 PM
my_slow_civic's Avatar
Default Re: mounting 4 point harness... (DOHCarp)
Get a rollcage. I had mine hooked onto that.
If the pic doesnt show up, which it probably wont, you can see it in this post: http://www.automotiveforums.com/vbul...hlight=harness :
Old Oct 13, 2002 | 03:54 PM
shoebox's Avatar
I put a 5 point in my hatch. All I did was put a 1200 pound eye bolt in the center of the floor under the seat. I have Simpson harnesses and they came with clips on all 5 ends. I just clipped all 5 ends to the eye bolt. I can't move my seat back all the way, but I don't need to. I bought a little higher of an eye bolt. You can bye ones that will sit lower. Just an idea I came up with. Hope you get it.
Old Oct 13, 2002 | 04:06 PM
kshymkiw's Avatar
Default Re: mounting 4 point harness... (shoebox)
That is a good idea
Old Oct 13, 2002 | 04:18 PM
FourthGenHatch's Avatar
Default Re: mounting 4 point harness... (kshymkiw)
I attached the lap belt to the door side mount, and the other to the seat rail since with the belt attached to the thing that the stock belt plugs into I couldn't get them all to fit so I had to take plug-in thing off, so later I just mounted it to the seat rail. For the vertical belts I ran them up top of the seat and then under it and bolted them to the front of the seat rails. Works great.
Old Oct 13, 2002 | 06:28 PM
travis's Avatar
Did I misunderstand something? You have your shoulder belts connected under the driver's seat? OMG!
Old Oct 13, 2002 | 06:45 PM
DaRnOk's Avatar
Sometimes I wish I never had mine. It can be a pain.
Mine is monted to the Very back where the rear window is.
Old Oct 13, 2002 | 08:07 PM
Magick211's Avatar
Default Re: mounting 4 point harness... (DaRnOk)
You really shoudnt use harness unless you have a roll cage, And if you have the shoulder harness slanted more that a 90 degree angle you are really gonna **** yourself up when you get in a wreck
Old Oct 13, 2002 | 09:06 PM
Cereal_Killer's Avatar
yeah mounting them to the floor is not good. that why even peole w/o out a roll cage use what is called a Harness guide bar. just a lil scenario for you, you mount them to the floor and god forbid you get into an accident you spine will compress! this happens cause all the force is being aimed down the spine and not across the shoulders (as in using a guide bar or roll cage)like it should be. i suggest you fix that.....SOON!
Old Oct 13, 2002 | 09:27 PM
95si's Avatar
Default Re: mounting 4 point harness... (91EFZC)
what about having special belts made that connect into the rear seatbelts?!
Old Oct 13, 2002 | 09:30 PM
LoooseGSR's Avatar
Default Re: mounting 4 point harness... (95si)
I heard that if you just do mild auto-x or just want it for looks and you have a rear strut bar, you can mount it to that, i wouldn't recommend it though...if you get in a wreck, that bar will bend and/or break
Old Oct 13, 2002 | 09:58 PM
Urban Business
Guest
Posts: n/a
Default Re: mounting 4 point harness... (PSUCRX)
using a harness w/o a rollcage is the worst idea in the world. saftey equipment is only usefull when used properly.
Old Oct 14, 2002 | 04:48 AM
DOHCarp's Avatar
where can I get a guide bar? or just a back half roll cage?
thanks
Old Oct 14, 2002 | 04:52 PM
travis's Avatar
True, that's what would happen if you mounted it to a sturdy place on the floor behind the seat. In his case, it's much worse. The force of your chest is transmitted directly to the seatback which cannot stand that type of force. Once the seatback breaks (which happens all the time, BTW), he's got enough slack in the straps to hit the windshield or even leave the car!
Old Oct 14, 2002 | 07:00 PM
THCRXsi's Avatar
i've been worndering the same thing e-mail me if you find a solution
RiceCRX@msn.com
Old Oct 14, 2002 | 07:16 PM
Driven's Avatar
Default Re: mounting 4 point harness... (THCRXsi)
More lovely stuff on rollbars/cages/harnesses
[Modified by Driven, 8:59 AM 10/15/2002]
Old Oct 15, 2002 | 06:35 PM
wadafa's Avatar
Default Re: mounting 4 point harness... (Driven)
Shoebox: dude, you are crazy, all 5 points of your harness to one bolt going throughthe floor, okay its a strong eye bolt so it wont break, but the floor will rip right out, and yeah you will completely f*ck your back since your shoulder straps go straight down, seat belts hold you in not down,
there should be threaded holes where under the rear seats, (or where they are supposed to be, for crx) use those, thats what they are for
b18LS
10
Nov 13, 2007 09:05 AM
Race Egr
Sep 23, 2005 08:34 AM
Stinkycheezmonky
36
Oct 30, 2003 08:13 AM
sporkcrx
Jun 22, 2003 11:03 AM
6ghatch
Jan 26, 2003 11:29 AM
