K - Series Long Blocks ( A3, A4, A8 )
Call/Text: Joel 909-728-9967
Prices: Non Negotiable
ALL LONG BLOCKS COME W/ 90-DAY WARRANTY
K20A3 - $950 I forget the mileage, but it's low, and it's out of a RSX AUTO. Has JDM Wrinkle Red VC!
Displacement: 1,998 cc (121.9 cu in)
Compression: 9.8:1
Power: 160 hp(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 140 lb·ft (190 N·m)* (191 N·m) @ 5000 rpm(SAE net J1349 Rev 8/04)
Redline: 6800 rpm
i-VTEC Engagement Window: 2200 rpm
K24A4 - PULLED FROM 04 ELEMENT $1000.00 ( NO CORE REQUIRED ) UNDER 45k
Found in:
2003-2005 Honda Accord(USDM), 2003-2006 Honda Element
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
Torque: 160 lb·ft (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
Redline: 6800 rpm
Cable actuated throttle
K24A8 PULLED FROM 08 ACCORD $1150.00 ( NO CORE REQUIRED ) UNDER 35k
Found in:
2006-2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 5800 rpm
Torque: 160 lb·ft (217 N·m) @ 4000 rpm
Redline: 6500 rpm
Electronically controlled throttle
Compression: 9.8:1
Redline: 6800 rpm
Found in:
Compression: 9.7:1
Redline: 6800 rpm
Found in:
Compression: 9.7:1
Redline: 6500 rpm
