Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sparco seat base
Old May 14, 2012 | 05:12 AM
civexspeedy's Avatar
Default Sparco seat base
I have a Sparco Sprint seat that I'm looking to put in on the passenger side of my '91 Si. Was about to go with Buddy Club rails until I found out they have fitment issues wth this model car for some reason. So I was looking into just getting the Sparco base simply to mount the seat. My question is, does the base mount have a location for the seat belt buckle to bolt into? Tried messaging Sparco but I haven't heard anything back, not surprised.
Old May 14, 2012 | 05:49 AM
markertoo's Avatar
Default Re: Sparco seat base
I actually found the EF to be the easiest generation chassis to mount an aftermarket seat in. Since the OE seat sliders mount on the bottom of the seat, it should be relatively easy to simply space out the sliders from under the seat, to get a flat mounted seat.
If I recall, I used a piece of 2" x 4" box steel to go between the seat and the slider on one side, and mounted the other slider directly to the seat base. I used the 2" portion for the height difference, and the 4" portion to make the width correct for the mounting of the slider to the floor of the car.
If this doesn't make sense, PM me, and I will try to explain.
Old May 15, 2012 | 03:37 PM
I would really rather not make a mount myself. Main reason being my concern for safety for anyone who rides shotgun. I don't trust my fab skills(or lack thereof) and I just don't have the time to mess around with it either.
That being said, does ANYONE have this base mount? Has anyone simply bolted the seat directly to the base without the use of sliders or side mounts? I just want to be able to mount the seat to the base(since it's the passenger seat, I don't care about sliding the seat). I also don't want to have to purchase the side mounts. I haven't looked at my Sparco Sprint seat in a little bit but I'm pretty sure it has threaded bolt holes on the bottom side.
If anyone has directly mounted the seat to the base, please let me know. Pictures would be great!
Thanks!
Old May 15, 2012 | 03:52 PM
johnjw's Avatar
Yes it does.
Old May 15, 2012 | 06:35 PM
dirty19's Avatar
Ridin Dirty in Cali
Seat belt buckle to bolt to?
Are you wanting to use the stock seat belts?
if you are... I wouldnt use a stock seat belt with it.
RSZero1
Oct 13, 2006 08:09 PM
red33gsr
Jan 11, 2006 12:56 PM
ED9man
28
Aug 29, 2005 06:36 AM
rice_classic
12
May 5, 2004 11:33 PM
spock_rocker
10
Jan 20, 2004 08:47 AM
