Rubbing noise coming from right front brake rotor. Pic included. Help Diagnose?
2002 Accord Ex V6
I think I have pinpointed where the rub is on the rotor. I've never really seen anything like it. It looks like it is rubbing on the inside portion of the rotor on the very outer edge (as you can see where my finger is pointing.) Just wondering if anyone else has experienced this before and what could be causing this to happen.
I compared this side with the drivers side and there is a definite difference. It doesn't seem like it is making the wheel hang up while turning it by hand compared to the other side. It has actually been rubbed so the metal is shiny. The other side is still "rust" colored like it should be.
The rotors and pads were replaced less than 20000 miles ago. No problems until now. Could something be stuck underneath the caliper??
Any help would be much appreciated.
Thanks
Thanks
That is the dust shield it is rubbing on. Either remove it (which is a lot of work) or just bend it back. Once you bend it back, just spend the hub (rotor) and make sure it isn't rubbing anymore.
http://www.autozone.com/autozone/par...uestid=1034991 the tiny rubber piece is what goes on the gap of the bolt
and this is what my guide bolt/pin looks like at the tip where the seal goes. i found mine deep inside the caliper
Sorry for the long wait for a reply. I finally found the time to pull the caliper apart. I did happen to be that the clip that hold the pads in was rubbing on the inside part of the rotor.
Hopefully this was the right thing to do... I decided to bend the clip back a little bit. I also compared it to the opposite side. The one side of the clip looked like it had been broken off, hence the reason it was rubbing in the first place..
I also did a brake job on my 2004 civic this weekend. There aren't any clips like that in the civic calipers. Just out of curiosity, is there a reason for that?
Thankfully, the brakes work and sound perfect now. Thank you for your help guys.
Can that clip be removed? I had the same issue for months and finally fixed that problem a few days ago, but it's starting to do it again today. I feel like taking it out so it won't do it anymore.
