Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 civic si clutch
Old May 13, 2012 | 01:22 PM
denisq6's Avatar
Default 06 civic si clutch
guys is there any DIY with pics of how to adjust the clutch on 8th gen Si's? i couldnt find one anywhere..thanks
Old May 15, 2012 | 07:41 AM
bee guz's Avatar
Default Re: 06 civic si clutch
It's not hard just pull the cover under the drivers side instrument panel, and look up.
Just make small adjustments( 1 or 2 threads at a time), be careful you don't take all of the free play out or you will be pulling it apart to install a new clutch.
Old May 24, 2012 | 01:10 PM
sstupid's Avatar
10 Year Member
If you happen to need new Honda OEM clutch/pressure plate/bolts, let me know. I bought all the stuff, then had to have a dealer install a new one because my clutch went out when I was out of state.
Old May 25, 2012 | 07:27 AM
denisq6's Avatar
no its just pissing me off how it grabs all the way to the floor when i let go of the clutch, and btw i still didnt do it yet, im afraid to touch it cause i never worked /w that. i really want it to grab midways
Old May 25, 2012 | 08:22 AM
dube_fa5's Avatar
http://www.dsmtuners.com/forums/newb...#post151955635
This video describes the proper CMC adjustment procedure.
http://www.4g63turbo.com/tech/eclips...djustment.html
The second link is a detailed step by step of how to adjust the hydraulic CMC. The only thing to take into consideration is the measurements of pedal height, clevis pin free play etc. since the link describes CMC adjustment for an eclipse, the measurements for an 06+ si will be different, but the rest of the procedure still applies.
Old May 29, 2012 | 08:09 AM
snizzletoff's Avatar
Scroll down to how to lower the subframe
http://www.8thcivic.com/forums/swift...on-videos.html
You will need to drop the subframe, this will require that you disconnect the lower control arms from the rotor or disconnect the rotor and LCA from the suspension...What i did was remove the 2 bolts that bolt the lower part of the suspension on, remove the ABS sensor wire and dropped the rotors and LCA's with the subframe.
After that's off follow this guide.
http://www.8thcivic.com/forums/trans...ng-clutch.html
GagnarTheUnruly
Jun 3, 2015 11:04 AM
fridaytech
Sep 26, 2007 02:05 PM
coupon
May 17, 2005 05:34 AM
wkrpfm
Acura TL, RL & ZDX
Dec 3, 2004 09:35 AM
MayhemSi
Sep 29, 2004 11:06 PM
