Civic EG9, B16A2 to JDM B18C swap
Old May 13, 2012 | 01:58 AM
fsl's Avatar
fsl
Icon2 Civic EG9, B16A2 to JDM B18C swap
Hello, my B16A2 177.000miles on it (still going strong...) and I want to swap it out for a JDM B18C. Afaik the motors are the same, except for deck height and the fact that the B18C was in an OBD2 car. So my question is, would it be sufficient with a B18c longblock, an OBD2-OBD1 harness and the ECU? I already have a transmission with LSD so I see no point in changing it, ITR transmissions cost too much anyway...
Sorry if this question has been asked before, but all I could find was D- to B-series swaps, as it seems nobody has the B-series stock in the states!
Also I'm looking to buy a cheap JDM B18C maybe in need of a rebuild?
Old May 14, 2012 | 05:16 AM
fsl's Avatar
fsl
Default Re: Civic EG9, B16A2 to JDM B18C swap
Okay so I figured its a direct bolt-on, but which ECU do I use?
Old May 14, 2012 | 05:44 AM
vtec-8400rpm's Avatar
use your stock ecu/ engine loom /sensors with a piggyback chip to fine tune - mine runs perfect like this
sam95teg
Apr 7, 2005 03:09 PM
Boosted
Aug 10, 2004 09:51 PM
1hotcivicSi
Feb 13, 2004 09:27 AM
civichb
Sep 14, 2001 11:27 AM
