Rod Bearings....
Old May 12, 2012 | 10:23 AM
athon08's Avatar
Default Rod Bearings....
what is the size for "stock" rod bearings. and are they all the same size across each cylinder or are all 4 different sizes?
Just a little insight of what's going on. Had a small knock between 2200-2500 rpm. pulled each plug wire one at a time. When I pulled the #2 plug, the knock went away. Dropped the oil pan and pickup. #2, 3 and 4 rods had very slight wiggle. #1 didn't have any wiggle. I removed all 4 rod caps and removed the bearings. #2 cap bearing didn't have the little tit on the side to keep in place. All caps, rods and crank looked good. no scratches or scaring. Would I be able to just throw some stock/standard bearings back in the block and call it good, or would I need to machine the crank? There was very VERY little metal in the oil, more like a metallic paint as compared to bits of metal.
Old bearings were all stamped with D8F 0.25...no colors. How can I tell what color I need? I've seen plastigaue, but that's just to check clearance on the right bearings, correct?
Old May 12, 2012 | 02:06 PM
Former User's Avatar
Default Re: Rod Bearings....
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old May 12, 2012 | 04:28 PM
athon08's Avatar
Oh yeah...duh
1999 Honda Civic Si. B16A motor. I'm guessing it's had motor work done before since ALL bearings are Over 0.25. The top bearing on the rod itself were worn down a good bit on #2 and #3 cylinder.
Old May 13, 2012 | 12:22 AM
jbpnoman's Avatar
For clarity sake, B16A, or B16A2? If it's a B16A, first, or second gen?
Old May 13, 2012 | 04:12 AM
athon08's Avatar
B16A2
AssPenny
13
Feb 22, 2014 07:51 AM
Phoenix5
Honda Civic (2001 - 2005)
Dec 23, 2013 11:07 AM
srmofo
Jul 20, 2009 10:59 PM
pjr710
Aug 18, 2008 11:18 PM
hybrid901
Mar 17, 2003 11:43 AM
