B&D-Series Turbo Pistons/Parts/Cams..ETC..PIC'S
Old May 12, 2012 | 01:54 AM
SlaminSohCivic's Avatar
Icon3 B&D-Series Turbo Pistons/Parts/Cams..ETC..PIC'S
Whats up Honda-Tech Ive Been Working Steady At Garage&Building New Set Ups And Getting Over Flown With Spare Parts...
If You Need anything i Dont have Listed And its 88-00 Civic/Teg AAsk me
Located Uniontown,PA
1.TURBONETICS Single Ball Bearing Turbo Made For a GNX.Its Oil&Water Cooled..Includes Down Pipe Flange That Flare's from 3" to 4"..Has a 38mm External WG Flange on Exhaust Housing...Similer to The GT40 FOR STI...$440.00 Shipped
What happen this Turbo was on a Gsr Turbo 20 Psi...And ran Beautifuly Then Started to Blow Some Oil out the Intake Housing And my Buddy Bought New Seals For it And Took Apart to Change Seals (He Wouldnt Wait For Me) And He Put Seals in then Must Have Cross Threaded The Nut That Holds Compressor Wheel to Shaft And Snaped the Nut off...But Bearings Were Perfect
2.(4) Supra Turbo 440cc Injectors...My brother just sent them to get Cleaned and Tested...Car Only Had 47,000 Orignal Miles But He got Remaped Or W.e to 550s...$110.00 Shipped
(If you Need a Injector Resistor Box...If u buy These Just Add $15 Bucks onto Price Package Deal!!!
3.92-95 Civic EX/SI Brand New Power Steering Rack...My Buddy Bought Last Year For His Civic That He Wrecked But He Never Put it in So i Got it...He Paid Like $225 Or sumthin Crazy ....$100.00 Picked Up $145.00 Shipped
4.(4) Injector Resistor Boxs...2 Have Plugs...And 2 Have Just Wires...$25.00 Shipped Each for Wires....$30.00 Shipped Each With Plug
5.B17A1 GSR DOHC VTEC CAMS...Mint Condition...$70.00 Shipped or trade
6.B18C OEM Oil Squirters...$25.00 Shipped
7.B16A2 99SI EM1 OEM Cam Shafts...78k Miles...$60.00 Shipped
8.
9.ECUS ....
~P06 OBD1 Ecu...Converted To VtEC&Data Logging Porte...And Chipped/With EasySnap Out Chipped Not Pull Out ****...$130.00 Shipped
P06 OBD1 5 Speed ECU...Virgen ...$65.00 Shipped
PM6 OBD0 5 SPEED ECU...$60.00 Shipped
p2p obd2 5 speed Ecu..$50.00 Shipped
P2E OBD2 AUTO Ecu....$40.00 Shipped
P07 OBD1 5 Speed Ecu...Has Burnt 1&4 Injector Resustor In Ecu...My buddy Said its Easy $35.00 Shipped
10.92-95 Civic Climate Control Unit..A/c to...$40.00 Shipped
11.B18 IVAC Good Conditon Came off Low Mile Motor...$55.00 Shipped
12.B16A Older Style Wide bolt Pattern good condition...$50.00 shipped
13.Wiseco Forged 81mm Pistons...9:6:1 Im or Maybe Little Lower...Allows Clearence For 1mm Oversized Valve Also...Used For 5,000 Miles..1 Piston is Brand New I Replaced It Because Other One Had Got Beat Up From Dropped Valve But all 4 Pistons Are Perfect Now...Also Have All 4 Wrist Pins..Upgraded Ones....And Clips...4 Sets of Brand New Rings...The Rings/1 New Piston Cost me $224.00 Alone Asking $400.00----->>>$355.00 PRICE DROP
14.B16/B18/B20 HYDRO BRAND NEW PRESSURE PLATE...OEM REPLACEMENT...$50.00 Shipped
15.94 integra OEM CLOCK $12.50 SHIPPED
16.Autometer Carbon Fiber EGT Gauge...Can Include Single Pod Also...Includes...Gauge/Single Gauge Pos/The Stainless Line/Wires Go From Exhaust to Gaugee...
17.AEM Black Silcone Coupler....$12.50 Shipped
Old May 13, 2012 | 10:42 AM
Default Re: B&D-Series Turbo Pistons/Parts/Cams..ETC..PIC'S
bump
Old May 18, 2012 | 06:33 AM
bump
theYBLEGAL
Mar 17, 2017 06:44 AM
schnell96
Dec 7, 2013 03:26 PM
Rootie524
Oct 21, 2012 12:00 PM
DefiantGSR
Mar 21, 2005 01:51 PM
T-sohctec
Sep 10, 2002 09:27 PM
