f20a sohc manual transmission to h22a engine
Old May 10, 2012 | 10:41 PM
Jdm Accords's Avatar
Icon2 f20a sohc manual transmission to h22a engine
hi there, i have a problem with my h22a auto gearbox inside my accord.. i have a problem to get a h22a manual gearbox to change my auto gearbox. is it possible if i use the f20a sohc manual from others accord gearbox to my h22a engine? is it possible that all the part can fit on my accord?
Old May 10, 2012 | 11:21 PM
holmesnmanny's Avatar
Default Re: f20a sohc manual transmission to h22a engine
Are you tryin to convert to manual from auto ?
Old May 10, 2012 | 11:31 PM
Icon2 Re: f20a sohc manual transmission to h22a engine
yes. because a lot of my friend that using h22a with auto gearbox already change thier transmission. is it possible to me to do the same things?
Old May 10, 2012 | 11:49 PM
There's a writeup on how to convert to manual. Just search for it.
Yes, you can use that tranny when you convert it to manual.
Old May 11, 2012 | 12:05 AM
that's mean the f20a sohc manual transmision can fit on my h22a engine without any problem... am i right?
is it hard to do the swap?
Old May 11, 2012 | 12:13 AM
Correct, the only issue you will have, perhaps, is extending the speed sensor wiring, if necessary.
I believe it is hard. And you have to source a lot of parts. It is doable tho.
Old May 11, 2012 | 03:02 AM
extending the speed sensor? why? are they different?
Old May 11, 2012 | 03:04 AM
can some one give me the diagram how to swap a auto to manual transmission?
Brownjd
Jan 27, 2011 07:09 AM
cozmoid
Transmission & Drivetrain
Jun 23, 2010 01:34 PM
bopbop93030
Jul 27, 2009 01:44 AM
iceman885
Jul 18, 2003 01:34 PM
Chubs
Mar 11, 2003 12:27 PM
