d15B8 into 91' STD starting issue
Recently bought a 91 DX hatch Auto 54k on the shell, everything was untouched bought from original owner.
Cam gear broke off and the car has been sitting for about a Year
I swapped the knuckles for Crx Si ones, pulled the engine and tranny.
bought a D15b8 from a 93 CX hatch, installed a DOHC ZC tranny(converted to 5 speed,Staying DPFI)
i wired it to make it think its in Park, and tried to start it today.
it cranks fine and is getting spark but its not getting fuel.
I thought it might be because I still have the Auto Ecu...Any help would be great,
Well, the ECU controls the fuel pump, so probably so. See this thread, on this page:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/pin-m-relay-sends-injectors-power-3054968/
This was my 69th post, btw. WOO!!!
Okay, Replaced Cap,Rotor,Plugs,Wires,And have my manual Pm5 in.
I'm getting fuel now which is good....BUT when i check for spark with just the wire I have it but soon as i put a plug in the wire its not getting anything......Sooo...
I fingered It out. I had to set the timing with the obd0 d15 distributor.
Because the Obd1 b8 distributor is slanted.
I'm stupid. thanks for helping hah
EG-Coupe
Nov 23, 2009 12:58 AM
