d series timing belt tensioner
Old May 10, 2012 | 07:53 PM
92lxsleeper's Avatar
Default d series timing belt tensioner
98 D16y7
my tensioner is making noise, so i'm wondering if its possible to change it without removing the lower timing cover and having to retime the engine? i dont want to pay to have the timing belt done at the dealer, and would rather just get the tensioner for now since the belt and waterpump look fairly new.
Old May 10, 2012 | 08:21 PM
90civicstdgold's Avatar
Default Re: d series timing belt tensioner
Its not difficult at all to set the timing on one.
And YES, you will have to remove the lower timing cover.
Old May 10, 2012 | 08:27 PM
oh i know its not hard to set the timing. id just rather not have to screw around with the engine. well im gonna call a couple places, theres a shop here that specializes in honda and acuras, so i'll see how much he will charge to do the timing belt set. maybe even look into doing the oil pump while the front of the motor is torn apart.
Old May 11, 2012 | 12:07 AM
furious94ls's Avatar
You can't get to the oil pump through the timing belt cover. The oil pan has to be removed. It's a seperate job. Why do you want to replace the oil pump?
The only job that has to do with oil in that location would be the rear main seal? Is that what you're talking about?
Old May 11, 2012 | 12:27 AM
SOL619's Avatar
Originally Posted by 92lxsleeper
oh i know its not hard to set the timing. id just well im gonna call a couple places.
"Real Girls Fix Their Own Cars"
From your sig, do it yourself
Old May 11, 2012 | 05:10 AM
i know and i should. i'm on some meds right now, and i dont have the patience to do anyting because of them >.<
95LssTeg
May 26, 2006 11:40 PM
mixmastabob
Mar 17, 2003 05:08 PM
B18EG6
Dec 2, 2002 06:59 PM
smkngsr
Jun 30, 2002 08:53 PM
