Code 3 problem
Old May 10, 2012 | 06:58 PM
codybuRr's Avatar
Default Code 3 problem
So im getting a MAP sensor code.
I've tried 2 different sensors, and a known working ecu.
I went back to check voltage. The yellow/red wire gets 5v and the ground is working correctly. The white however is getting 0v both at the connector and ECU. Does this just require a replacement of the white wire?
Old May 11, 2012 | 08:23 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Code 3 problem
Do a continuity check and you will have your answer...
Old May 14, 2012 | 09:09 AM
codybuRr's Avatar
bumpity, still can't figure this out.
cmwalker
Oct 8, 2012 12:14 PM
itslogz
Jul 19, 2010 07:17 PM
hondaEg_808
10
Jul 3, 2010 08:46 PM
user 98292739
Jun 26, 2006 11:35 AM
se93
Oct 14, 2002 10:37 PM
