Installed new rear hub assembly, normal for bearing to be stiff?
Old May 10, 2012 | 05:46 PM
egvtec's Avatar
Default Installed new rear hub assembly, normal for bearing to be stiff?
specific to rear disc brakes with a bolt on hub assembly, installed a new hub assembly, anyone ever had this experience with the new bearings? it is properly installed and torqued to factory spec. I was told once i drive it the bearing will free up but i want to double check before test driving that this is normal for it to be hard to turn the bearing before driving on the new one.
Old May 10, 2012 | 08:54 PM
Donkey85's Avatar
Default Re: Installed new rear hub assembly, normal for bearing to be stiff?
like how stiff are you talking? to the point where you have to put a lot of muscle in it to turn the wheel or just its take a very little effort, but dosent just spin like a top?
Old May 10, 2012 | 09:38 PM
98civdx's Avatar
Master Detailer
^ That.
The bearing/hub should be move freely and easily.
Take the car out for a drive.
Old May 11, 2012 | 04:20 AM
egvtec's Avatar
its taking some muscle, to turn it, i dont know why it tightens up like that
Old May 11, 2012 | 05:12 AM
92lxsleeper's Avatar
its not on right then. it should be easy to turn, but should feel like its sticky like honey. you can turn it easily, but it wont keep spinning when you stop.
MarkCayabyab
Oct 7, 2017 11:40 AM
papa-g
12
Mar 16, 2010 12:16 PM
DmcL
Nov 8, 2006 09:15 AM
Tiamat-blue
Aug 19, 2002 08:10 AM
jasonb
Jun 22, 2002 07:17 AM
