2000 Si w/B18C swap just started idling at 1500 and sputters from 800-1500 in neutral
Old May 10, 2012 | 01:17 PM
cheeblez's Avatar
Default 2000 Si w/B18C swap just started idling at 1500 and sputters from 800-1500 in neutral
Hey i got this civic si with a b18c swap a few weeks ago and all has been good until today when i noticed the idle jumped to 1500rpms. I don't know what happed or why it is at 1500 and not 800ish like normal. What could be the problem. The car drives fine other than that.
Old May 10, 2012 | 01:23 PM
Dc4LsTeG's Avatar
EK9
Default Re: 2000 Si w/B18C swap just started idling at 1500 and sputters from 800-1500 in neu
Try cleaning your iacv
Old May 10, 2012 | 01:28 PM
cheeblez's Avatar
Would the iacv seem like something that would cause this problem to come up so suddenly without any early symptoms of the idle slowly increase over time?
Old May 10, 2012 | 01:42 PM
Dc4LsTeG's Avatar
EK9
Could be. Id also check your throttle cable,tb plate, and check for vacuum leaks
Cjkelley87
Sep 6, 2012 10:12 AM
CrowerRex
Dec 29, 2004 07:18 PM
