Leaking fuel injector
I have a 90 Crx si with a 91 b18a and its not running that quick right now and im trying to figure out what the problem could be. I got to looking at the number 2 fuel injector area and its leaking some fuel out not a whole lot but it is leaking some Could that be causing to loose a bit of power?
[Modified by CivicBoyZC, 9:34 PM 10/13/2002]
are your injector plugs all in the right place? misfire could cause poor performance. i really got good use out of the fuel pressure gauge i got. can you describe the poor performance you are feeling? off the line? what gears are you feeling? are you getting full throttle?
Well its only leaking a little bit, But now i think i found the real reason its not performing as good as it should,
I pulled the number 1 spark plug wire out and it was drenched in oil
and there was oil all in the spark plug gallery thing number 2 had a some also but less than number one, im hoping its the oring gasket things on the valve cover if not then it could be the head gasket i hope now
dirtycolombian
Aug 29, 2007 12:23 PM
