no starting out of ideas help
Old May 9, 2012 | 04:56 PM
hypeonline's Avatar
Default no starting out of ideas help
My 90 hatch started running like crap i took the dizzy off and the car just started the cycle of crap, it would start but run even ******* and stall under load, and cough stared happening and smoke started shooting out of the intake, so i just went on a rampage of changing things that include
-the head
-timing belt
- water pump
-dizzy cap and rotor and ignitor
-plugs and wire
-checked the timing
-main relay
-tensioner
After the head change the cough lighted up to occinally im at my wits end
Its not starting and making a coughing noise when i try to start it its a d15b2 any help would be awesome
Old May 9, 2012 | 05:50 PM
lazy14's Avatar
Default Re: no starting out of ideas help
maybe clogged cat????
Old May 9, 2012 | 07:30 PM
hypeonline's Avatar
The cat is off at the moment so can't be that
Old May 10, 2012 | 06:10 AM
hypeonline's Avatar
Anybody???
Old May 12, 2012 | 11:33 AM
hypeonline's Avatar
My car is shooting gas back up though the throttle, any one know how to get it straight
Old May 13, 2012 | 08:20 AM
93delsold16z6's Avatar
backfiring? running too rich?
Old May 14, 2012 | 09:16 PM
hypeonline's Avatar
its not even starting, i though it was the dizzy change the ignitor, then got another dizzy nothing, i checked my plugs to the dizzy and no cuts or frays, i have no idea what it could be, i keep checking the timing and its like i adjust it and its on but no love, ill get a vid up of its doing as soon as i can
Old May 16, 2012 | 07:51 PM
Advance the timing using a distributor. I had a civic that wouldn't start. Advanced the timing and started up after a year!!!
Old May 17, 2012 | 12:00 AM
213374U's Avatar
0x5359-0055
Community Builder
Basics: Spark? Fuel? Compression?
Old May 17, 2012 | 12:05 AM
Swap'DShuttle's Avatar
If you're shooting fuel into and or out of the intake and you're possibly getting pop-back basically, sounds like mechanical timing is off.
swapped95
10
Sep 29, 2007 09:01 PM
swapped95
Sep 29, 2007 01:29 PM
swapped95
SmogTech01
17
Jan 27, 2005 08:34 PM
TiggsCRX
94
Jul 11, 2004 12:57 PM
