92 Accord No Power Steering... Replaced Rack and PS Pump
I have a 92 Accord EX. I was having issues with handling and a leaking Rack and pinion. I replaced the rack and got an alignment. After the replacement and alignment, I have no Power Steering. I wound up replacing the pump, but the problem was still not solved. Then I replaced the PS fluid reservoir today after being told there is a screen/filter that clogs up. This still has not solved the problem.
Does anyone have any idea what could be preventing the PS assist to work? i want to see if I can diagnose this before I take it to the dealer.
I bled the system completely. No bubbles in the reservoir. I go tthe wheels off the ground and turned from end to end for a while but still no PS when i sat the wheels back on the ground.
They all went into the new rack exactly where they came out (they are hard lines so it is difficult to reconnect them in the wrong place). I don't believe any lines got kinked bu tI will be double checking. If there are no kinks in the lines going to the rack, is there anything else I can check? Also, all of the lines on top (PS reservoir and PS Pump lines are definately not kinked).
now y did i not think about this. his right. if your not using power steering fluid it will cause problems. a while back my power steering had a leak used some power steering stop leak the only thing it did was make the power steering harder and never stopped the leak. replaced fluid and it was like new with new power steering lines
FMohlmann
Nov 18, 2016 12:28 PM
BigTwigs1981
Sep 4, 2011 11:27 PM
