low 12sec Honda civic WAGON
here's my daily driver.. my girl and I have been putting some hard miles on this build the last 1 1/2 and I just wanted to share a little bit enjoy!!
Its a RT4wd 88 civic wagon with a built D16z6, gt3076r turbo
here's a little video we put together.. http://www.youtube.com/watch?v=84Um-7TfwNk
custom built the manifold myself
Everything you need to copy the build has been shown in the pictures provided. Some crazy hot side piping to a back door setup (unless more craziness behind the bumper). The cold side is your typical placemet. Then the exhaust is offset and ran this way down the exhaust tunnel. Your typical setup - nothing fancy. '88-91 turbo setups were never "meant to be" haha.
The key to make more power with my current setup is a larger intercooler & maybe the manifold, this same engine and same turbo was on my 95 coupe running E85 topmount manifold & larger intercooler I made 530whp at 30psi, the coupe also ran 10.7 @135. I've had thoughts of getting the power up there and getting this wagon into the 11's.
Some Information:
http://ht-archive.org/showthread.php?t=2991272
Builds:
http://www.epictuning.com/4wd-civic/
http://wagonattack.com/about-the-wagon/
There a quite a few more informational posts and builds as well. I can't find the one where I posted TONs of info right now (my phone makes it slow to search). The CRV system has been proven to get maxed out around 600whp-ish. Regardless, there are even "how-TO's" for LSD, rebuilding TCD and VS units, ect ect... Just look around.
Builds:
Some Information:
Builds:
Builds:
The Epictuning coupe build was a CRV transmission with RT4wd wagon rear end, the Epictuning 4wd EF only had around 350whp with the standard civic wagon transmission/drivetrain. The wagon attack guy was running around 300whp. I guess what I'm sayings is I have never heard of anyone running a standard civicwagon drivtrain with over 400whp. I believe the weak link is in the transfer case of the the RT4wd transmission, I think the CRV may have a stronger transfer case.
I see this every now and then around 82nd or while driving by vip. Everytime i see it I wonder if the looks are backed up by power....and yes that beauty is. Nice to see some pics of this thing. I will be at pir one of these weekends and look forward to seeing it run.
We like to go down to PIR and make a few pass's now and then. We when out about 6 weeks ago and made a few pass's.
Engine/Drivetrain
-cp pistons 76mm
-eagle H beam rods
-I ported the Po8 head and run standard size 6000 series fierra valves
-Crower valve springs and retainers
-Crower stage 2 turbo cam
-ACL bearings
-Ported OIL pump
-ARP head studs
-1000cc injectors
-GM 3bar map
-P28 chipped and tuned with Crome
-Tial 38mm waste gate
-HKS SSQv BOV
-Clutchmasters stage 4 clutch with six puck disc
-OBX LSD in rear diff, this is a shelf d-series LSD, ring gear needs to be drilled out other than that its a direct bolt in.
-GT3076R turbo, I think its a .82 exhaust housing if I remember correctly.
-Custom VIP rear Diff bushing modd that I came up with, keeps the rear diff from making a god auhhfull clunking noise.
got ya, thats cool! When I had my D series I was blowing gears,diffs every 5 or 6 months at about 400 but they were cheap and wasent that big of a deal. I drove it hard too lol but good to hear the 4wd ones are alittle stronger (im sure they are hard to find)
