2004 civic si disc changer
Old May 9, 2012 | 02:36 PM
brandon15208's Avatar
Icon2 2004 civic si disc changer
my 2004 civic si says it has a 6 disc changer but it will not exceed 1 disc any ideas what is going on?
Old May 10, 2012 | 04:26 PM
hatchbobcat's Avatar
Default Re: 2004 civic si disc changer
Are you trying to load the discs into the player in the dash? If so the changer is located in the trunk area and should have a cartridge with it
Old May 16, 2012 | 12:13 PM
I am trying to enter it into the dash CD deck do I insert them into the changer in the truck if I can find it or into the dash?...
Old May 17, 2012 | 04:20 AM
TouringAccord's Avatar
H-T Order of Merit
I believe the deck lists 6-disc on it, showing that it is capable of controlling a disc changer but you need a disc changed to be able to have multiple discs loaded at once. The disc changer is usually located in the trunk, connected to the deck via a cable and has a magazine/cartridge that you load the discs into, then as you select the disc you want from the deck the changer loads that disc and is ready to be played.
This is just from my general understanding of cd disc changers, I've only had my 04 Si for a week
Old May 18, 2012 | 08:20 PM
So I need to go buy a disc changer? Or does it come with one in the trunk I have to insert the CDs in.. thanks for the respond have been trying to figure this out for like a month.
DT_Ghostly
Audio / Security / Video
Jan 16, 2012 05:02 PM
mskibbz-T
Jun 25, 2005 08:13 AM
