FS: Tons of parts (240SX SR20DET Redtop)
Old May 9, 2012 | 10:23 AM
forceinducted's Avatar
Default FS: Tons of parts (240SX SR20DET Redtop)
Posting this for a friend. Contact him at robertcatral@yahoo.com
Parting out or selling the car. 12k for the car
1992 Nissan 240SX Coupe
Engine:
SR20DET Redtop (fresh OEM rebuild by Touge Factory) $3000
Z32 Mass Airflow Meter $100
Greddy Suction Kit (Intake)* $150
HKS 256* Cams $200
Peak Performance Rocker Arm Stoppers $40
JWT Bored-Out Throttle Body $150
Megan Racing Exhaust Manifold $75
Megan Racing Turbo Outlet/3” Downpipe/Test Pipe/Exhaust $150
Garret GT2871r .63 Ball Bearing Turbo $900
Stainless Steel Oil/Coolant Turbo Lines $90
Stance Clocking Adaptors for Turbo Piping $70
ARP Head Studs* $60
Cosworth Head Gasket* $90
Nismo 740cc Injectors $300
AEM External Fuel Pressure Regulator* $100
Walbro 255lph Fuel Pump $50
C’s Short Throw
Exedy Stage II Clutch/Pressure Plate $100
Shaved OEM Flywheel* $100
Avid Solid Motor/Transmission Mounts* $175
Enthalpy-Tuned ECU $400
Stance Water Pump Pulley $60
Stance Coolant Temp Sensor Adaptor* $30
S14 SR20DET Water Pump* $50
S14-Style Water Neck with -8AN Fitting Welded In $30
Mishimoto Aluminum Radiator $100
Spal Dual Electric Fans $200
Stance Oil Filter Block-Off Plate $120
Greddy Oil Filter Relocation Kit $100
Maxspeed Oil Cooler with Custom Stainless -10AN Lines $50
Greddy-Style Oil Pan w/Internal Baffles $50
Electronics:
Blitz Dual Solenoid Boost Controller $100
Greddy Multi Switching System for Dual Fan Control $100
Kenwood Navigation/DVD/CD Double DIN $200
Autometer Phantom II Gauges
Chassis/Brakes:
Stance Coilovers $800
Tein Inner/Outer Tie Rods $100
Peak Performance Tension Rods $150
Peak Performance Rear Upper Control Arms $175
Peak Performance Rear Toe Rods $125
Stance Rear Subframe Spacers $30
5-Lug Conversion Front/Rear $400
Evo VIII Brembo Front Brakes (w/Skullworks Adaptor Brackets) $400
Z32 Rear Brake Conversion w/Parking Brake Assemblies $100
Z32 Master Cylinder $175
Stainless Steel Brake Lines $75
Drive Shaft Shop 1-Piece Aluminum Driveshaft $300
Nismo 2-Way Differential $600
Ate Super Blue Racing Brake Fluid
Autopower 6-Point Bolt-In Cage $250
S14 Dash Swap $150
Deleted All Creature Comfort Items (Heater/AC/Blower/Carpet/Interior Panels/Sunroof/ETC)
17x9.5” MB Battle (4 Gunmetal, 4 Bronze)/Various Drift Spares $300/set (1 set new, 1 used)
Exterior:
S14 Kouki Front End Conversion (OEM Kouki Healights/Hood) $500
20mm S14 Conversion Overfenders $250
Origin Stylish Aero
*Parts installed but engine never turned on after rebuild
Please contact him for some other parts that price are not listed at robertcatral@yahoo.com
I just copied and pasted what he sent to me.
Will post more parts-specific pics this weekend.
Thanks for looking!
Old May 12, 2012 | 11:10 PM
jdmeg6r13s's Avatar
Default Re: FS: Tons of parts (240SX SR20DET Redtop)
Post this stuff in zilvia.net hel sell Alot of these parts,I already emailed him for the mounts and clutch
PilotOnDubs
Aug 2, 2011 08:33 PM
mRek9R
Sep 17, 2010 10:58 PM
EJ8chu
May 4, 2009 11:11 AM
