Biggest Baddest B series out there for sale
I have a jdmb20b darton sleeved block 86mm bore decked block arp main studs endyne girdle line honed acl race bearings brand new oil pickup brand new type r oil pump brand new water pump Moroso oil pan micro polished ls crank eagle rods wiseco 14.5 comp pistons have head on block head is a fully built Gsr head with full supertec valve train guides seals everything head was professionally ported and polished with competition valve job with bowl blending has flat valves 2 bump compression higher head was also decked also comes with golden eagle lsv kit 8.8 lb comp flywheel and Gsr tranny no intake mani just block and head will also throw in a Gsr tranny this motor was assembled by rce machine in new Milford ct if you want a k killer this is motor for you I will promise u with good cams this motor should put down 260 plus whp on the low side asking 3500 firm no money to finish
K PORT
Northeast (Sales)
Nov 23, 2012 07:16 AM
bnut510
Northern California (Sales)
10
Sep 20, 2007 06:54 PM
morgan@synapse motorsport
Apr 16, 2006 02:25 PM
