Civic doesnt roll like it should
Old May 8, 2012 | 05:32 PM
TravisBiggie's Avatar
Default Civic doesnt roll like it should
When I had the car on jack stands, I spinned the wheel and it stopped like there was resistance, what is the problem? Also, when I started the car on jack stands, the wheels would spin when in neutral (5 spd) is this normal as well? I could stop the wheel with my hand when it started to spin.
Thanks
Old May 8, 2012 | 05:38 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Civic doesnt roll like it should
You're right there looking at it. Where does the binding seem to be coming from? Brakes? Bearing?
Old May 8, 2012 | 06:40 PM
I have a feeling its the brakes. The pedal is super soft, Ive been wanting to change them and bleed the whole system. Can you tell me what would be the easiest and cheapest way to convert my civic to rear disc?
Old May 8, 2012 | 07:05 PM
Hidenplanvew's Avatar
Theres going to be some resistance the brakes should drag alittle and yes the wheels spining on jack stand happens..
Cheap and easiest way ... just leave your drum brakes on.. Theres toms of write ups on how to do it and what you need.. your looking at like 4 to 5 hundred to do it correctly
Old May 8, 2012 | 11:09 PM
furious94ls's Avatar
The front wheel has resistance? check the pad, if they are more worn on one side than the other then you most likely have a stuck caliper. Buy a new one. bleed the brakes.
Old May 8, 2012 | 11:34 PM
jbpnoman's Avatar
The hell are you smoking? You can do a full rear disc conversion, with proper parts, for <$200.
OP, if you want to do a rear disc conversion, get the rear trailing arm assembly out of either a DC, or an EM1, as well as the e brake cable from the donor car. That includes the rear trailing arms, calipers, caliper brackets, and wheel hub assy. You can find them on eBay if you're willing to search long enough, for $150-$250. Alternatively, start junk yard diving.
DigitalFusion
23
May 21, 2019 07:45 AM
rc2904
Feb 14, 2015 08:17 AM
xXxHOLYMANxXx
Suspension & Brakes
Oct 8, 2010 08:15 PM
Gonzo_SiR
11
Mar 11, 2004 11:48 AM
